Yes they can befuddle a power supply such that it takes being off overnight to come back. When can I meet your friend?
b
Darbee Darblet
Readers of this thread and followers of the Gospel according to Mr. Bob will find this little box, which is added to the HDMI chain before your output device (CRT or otherwise), amazing. The best analogy I can think of is, if you turn your surrounds off and on, sometimes the difference is dramatic but most of the time it's subtle, but you still want them on. This does the same for video.
Read about it here:
Discuss it here (link is to some nice screenshots):
http://www.avsforum.com/t/1399154/darbee-vision-darblet/4500#post_22545807
Buy it here:
http://shop.avscience.com/DarbeeVision--Darblet-DVP5000_p_351.html
Just in time for the holidays, and the price went DOWN recently!
Michael
Readers of this thread and followers of the Gospel according to Mr. Bob will find this little box, which is added to the HDMI chain before your output device (CRT or otherwise), amazing. The best analogy I can think of is, if you turn your surrounds off and on, sometimes the difference is dramatic but most of the time it's subtle, but you still want them on. This does the same for video.]
Can you be a little more specific in what it has done for your TV? Does your HDMI chain include a Fury?
In my case it would go through my DVI port.
I've been intrigued with this thing for months.
Cheers.
The best analogy is the one I came up with for surrounds. It's not dramatic, like subwoofers. You can't call it "sharpness," since it's not that. Depth? Okay, but what does that mean? It's an improvement, better "definition."
I've used it for everything from old TV show DVDs to OTC SD and HD to SuperLeo's demo disc and it didn't make anything worse, and made most "better."
I don't have a Fury, but I'm sure someone on the Darbee thread does.
Most places give you at least 15 days to try it. It took me about 10 minutes to determine it's a keeper. Which is good, since I got an open box and wouldn't have been able to return it, anyway.
I don't want to turn this into another Darbee thread; I just thought people here would be interested enough in this device to pursue it elsewhere.
...thinking power supply probably won't fix, but it won't hurt to try I guess. Any tips on D board fix for this?
...convergence was otherwise good. Picture was good overall.
Here's a 60" that was $500 a week ago (and, probably as a result, is out of stock now):
The 73" has been about $1000. Check DealNews (yup, the 82" for $1400 is calling out to me).
That was me, and he did. And the set and I both lived to tell the tale.
I continue to recommend phone consults with Bob to anyone hesitant about any of these projects.
And you SHOULD be hesitant.
Have fun, and enjoy your set.
Michael
I am SOOOOOOOOOO thankful I didn't get anything bigger than a 51". When the day comes, it won't be difficult much more than spliting the cabinet, another great feature.
