AVS › AVS Forum › Display Devices › Rear Projection Units › Don't dump your CRT RPTV!
Don't dump your CRT RPTV! - Page 67
post #1981 of 11764
Originally Posted by boe View Post
i have a mits WS 65813 (I think) and the picture looks great - I've tweaked it and it does indeed look about as good as most new units.
I would like to get something new to replace it but not until they have good 80" TVs (I don't want a projector due to fan noise/space/renting apartment). ALso I want HDMI connectivity which my TV does not have - it has DVI but doesn't look as good on this model as component. Lastly HTPC's don't look good on this even if you tweak powerstrip.
You haven't even come close to seeing what the 65813 can do. The 11-step grayscale and gamma correction, image sizing along with video processing, of the Lumagen, takes it to a whole new level. My 65813 was beyond terrible without calibration and the I2C EEPROM tweaks, a lot better after, but even more so when I added the Lumagen.
I don't see a difference in the picture with the 1080i RGBHV or the DVI input from the Lumagen. Currently using the RGBHV, the DVI/HDMI is going to the Projector.
post #1982 of 11764
Originally Posted by barry728 View Post
I saw on Craigslist some of the Mitsubishi's you mentioned going for $400 or less. For another 5-6 hundred you can have as good a picture as good as there is. Also these sets last and last and last. It seems like more people should be doing this.
I am assuming you mean springing 5-6 hundred for a calibration on the set you know own? Wasn't quite sure what you meant by "another 5-6 hundred" till I tried reading between the lines -
Was I right?
Mr Bob
post #1983 of 11764
For Mit's, I would also recommend the CraigR anti-ringing mod. I have seen what it does, and was VERY impressed. It puts it up there with the ceiling pjs.
You definitely should apply it to yours. It does things for all RPTVs using a certain IC in their CRT socket boards - the last line of defense in CRT tech - that even a Lumagen can't take care of.
I believe Sony also uses this IC as well.
Mr Bob
post #1984 of 11764
Originally Posted by Splicer010 View Post
And it never will be, even with an upconverting player. Standard DVDs are not formatted to 1080i or 1080p...They are formatted @ 480i...You will never see true 1080i (the maximum your display can achieve) unless you get a HD-DVD or Blu-Ray player as Mr. Bob stated.
As to whether or not your display upconverts to 1080i, it does...The TV will convert whatever the signal is to its native resolution which is in yours (and my) case, 1080i...I hope this helps to explain what you were wondering about...
Sorry, Charlie. A Tosh CRT RPTV does not upconvert everything it sees to 1080i.
It upconverts everything that comes in as 480i to 480p, as all HDreadys do, and some brands do upconvert 720p HD to 1080i HD. Others that are CRT based don't recognize 720p at all.
But the Pioneer x30 series - the 530/630/730 series - was the only model year where the set was equipped with the advanced circuitry necessary to, upon command, upconvert 480i/p to 1080i.
My roomie says his Sony RPTV was also capable of this upconversion.
I have not seen any other CRT RPTVs do this, definitely not the Tosh's.
Sorry!
Mr Bob
post #1985 of 11764
Some times, when you need to do mechanical focus from the front, I use clamps and raise the screen enough (10"-12") to reach in to adjust the lens, but still see the pattern on the screen. With many that can be done from the rear, I have a high resolution camera and monitor, a friend can also be used. If you use a crosshatch pattern, you should be able to see the breaks in the vertical lines created by the scanlines. A free DIY tip!
Couldn't that be done by looking at the image in the mirror just as easily???
post #1986 of 11764
Everything you get other than the HD/BR discs will be a max 1080i. There are no 1080p broadcasts.
And there won't be for many, many years. Look how long it took to get digital implemented into the infrastructure, much less HD. 1080i capable broadcast electronics installation/implementation has taken years and years just to get this far, and there still needs to be a federal mandate in place to keep it happening to its totality.
NOBODY is going to be upgrading to broadcast 1080p for the forseeable future, just think of the bandwidth limitations THAT would cause!
The changeover to 1080i via component is a very solid signal, you don't need to worry about bandwidth. It becomes a matter of the D/A conversion, some players do one better than the other (HDMI vs. Component).
Not all 1080p projectors are the same.
And some displays do it better than others. For 1080p from 1080i - ALL broadcast media for the forseeable future - p displays MUST upconvert from i broadcasts. Some brands are good at this, and some are REALLY schlocky.
Stick with CRT tech and you don't have to worry about that.
Mr Bob
post #1987 of 11764
Sorry!
Mr Bob
So you mean to tell me that my Toshiba 51H83 (which accepts all input signals with the exception of 1080p) does NOT upconvert a 480i signal to 1080i as I have been told that it does??? Isn't my set a 1080i native set???
post #1988 of 11764
No, my camera magnifies the image (2-3x or so) and when I do it from the front, I am about 1' from the screen.....
post #1989 of 11764
Many CRTs were 480p and 1080i. Cheaper to produce that way. If you put a 480i DVD image in via a good video processor at 1080i or 540p you will be amazed at the difference.
post #1990 of 11764
Nothing beats the Cantilever Technique. I have tried them all, and nothing else is easier compared to its absolute effectiveness, nor gets it any better.
Mr Bob
post #1991 of 11764
Your set, as all CRT RPTV tech is, has a native res of 480p and 1080i, the image structure of each being in a completely independent memory bank from the other. It can't be any other way, as those 2 scanrates are completely different, the HD one being roughly 2.5 times more dense than the 480 one.
Some do more, but all of them are the same on that basic minimum of design of HDreadys.
Mr Bob
post #1992 of 11764
Nothing beats the Cantilever Technique. I have tried them all, and nothing else comes close.
I can easily disagree with that!!!
post #1993 of 11764
OK, I have changed my original statement above - you're right, it was an over the top statement, and not thoroughly thought out on my part. Sorry.
I must confess I am only now hearing about your camera/monitor method, and am very impressed with it.
But do you carry all that stuff with you on calibrations???
I would challenge your camera/monitor method to being better than mine, tho, and I think it is a lot more cumbersome.
I don't think it can get any better than the CT, even with monitor/screen usage. And the whole RPTV display screen has to be taken into consideration. Just getting the middle perfect is not always sufficient, in terms of the scheimpflug of each individual screen scenario. Sometimes a balance has to be struck, as is the case witn many facets of calibration.
Shall we agree that both of our methods are the best available, and will render the finest results possible?
Mr Bob
post #1994 of 11764
Mr Bob
Many techniques will work, it is the skill of the technician that makes them work. If the results are equal, it doesn't matter what method is used unless you are paying/charging by the hour......
Yes, I always have my camera and PVM-96 in the Jeep. It is a high resolution B&W machine vision camera capable of focusing very close to the screen, like 16"..... another benefit is that blue is extremely visible. Works wonders on FP CRT focus (convergence when needed to be done at the projector)
Cumbersome is doing focus from the rear access without the camera/monitor....
post #1995 of 11764
You got that right! On all counts.
I once did the Raychem amphitheater, with a rear pj'd 20' screen pj'd from a Barco triple-gun, with manual trimpots for the convergence, and mounted on the celiing (can you say, "ladder"?...). Screen being maybe 18' away from the pj.
To really get it right, it woulda been very helpful to have had binocs, but most binocs woulda been too strong!
I got a lot of exercise that day -
Mr Bob
post #1996 of 11764
While I did spend a full hour tweaking my TV, I'm sure an expert calibrator could do a much better job - still blows the doors off most of the untweaked stuff I see at Magnolia or Ken Cranes. However all the tweaking in the world isn't going to make it 80" or display a PC videogame to perfection. If they made an 80" CRT RPTV that was 1080p (want it better for HTPC gaming) I wouldn't be shy about getting it provided it came apart easily as I would imagine it would weight about 350lbs.
post #1997 of 11764
At 80" you will need a projector. The JVC RS1 has the 15000:1 native contrast ratio to be a good replacement for a CRT. You can get by with a DIY screen and table or shelf mount the projector.
post #1998 of 11764
Was I right?
Mr Bob
Yes. Buy a used RPTV for almost nothing and have it cleaned, serviced and calibrated for 5-6 hundred dollars.
post #1999 of 11764
We are starting to get some viable options, some newer displays are getting better and cheaper. The decision to buy used, a VP and calibration is getting more difficult. While the newer displays may look good they still need calibration to be a contender. I will be keeping my Mit CRT for a while, can't justify the 65" plasma cost........ With the new lower price on the JVC RS1 projector, going FP is definitely an option....
post #2000 of 11764
Mit made an 82" LCOS RPTV for awhile there. Only $20K out of the starting gate, prolly find one for $2-3000 now - if you can find one at all. All Mits's above a certain size have always come apart, would think it would be no different for this model, but be sure to doublecheck on that, I am not certain.
Pretty sure it was 1080p, too.
All Mits above 65" have always had a mylar mirror for the weight factor. Would expect that would apply here as well. With a front surface HD grade glass mirror you'll get 25% more light output than from mylar, from what I've heard. Which is irrelevant if it's bulb driven anyway, I suppose -
It was several years ago.
Mr Bob
post #2001 of 11764
Absolutely!
Just doing the optics cleaning on your CRT RPTV restores it to virtually brand new condition as it is, when run at videophile non-Torch Mode contrast levels, meaning midway of the bargraph on most brands, and 35-40% up on the bargraph on Mits's.
Not calibrated, of course, and drifted off on the convergence, as happens with all brand new sets during the first 100 hours of operation anyway. And with the grayscale drifting off over the years, but never ON in the first place anyway, when brand new.
But virtually brand new nevertheless.
Buying a used one cheap and getting the optics cleaned is the deal of the century.
Under videophile viewing and usage conditions, CRT RPTVs have an EASY 10 year lifespan, of looking as good as new at all times.
And with videophile calibration, looking BETTER than new for the entire 10 years!
Mr Bob
post #2002 of 11764
Mr Bob
Thanks I checked out the Big Mits when it came out - it wasn't bad but it wasn't great either. I'll definitely want something AT LEAST as good as my current TV but with 1080p for gaming. I'd love to go projector but I would want it in a seperate room for sound and space reasons - I rent currently. Big TVs at reasonable prices are definitely coming - just not soon enough for me
post #2003 of 11764
1080P gaming is Over-Rated right now due to developers not creating titles rendering @ 1080P. So anything running into a 1080P TV is actually being upscaled. Here are a few gaming shots from my CALIBRATED 57" CRT running in 1080I:
HL-2 Orange Box
NBA 2K8
Soul Caliber 4
Gears of War
post #2004 of 11764
Bob,
I'm new to the forum, but I have a story for you. I still own and use constantly a Pioneer Elite PRO-98. In the fifteen plus years I'v owned it I had only two services necessary even after a move from Fla to Ky and then to NY where I presently reside. The first was a tube and just this week had a convergence chip and cold solder joints fixed. I had the problem you have discussed many times over with the unit turning off after standby mode. I followed your advice, left it alone and called in a professional. Total cost for both repairs was about $300.00 each time. I am very satisfied with this unit and so is my 10 Yr old son with his Playstation even though he was not born when I purchased it. Love it till it dies. Thanks for your advice and I think I maybe interested in having you talk me through a cleaning. Please contact me if possible CC.Harley@Hotmail.com
Tx
CC
post #2005 of 11764
Originally Posted by cc.harley View Post
Bob,
Tx
CC
Great! Email is on its way, with pricing info.
Be sure to report in here with the results, after you've gotten them clean again.
Mr Bob
post #2006 of 11764
I have the same Sony also,just had it calibrated and the picture is very good.I am thinking of going Pani,42" plasma.I have been looking for a difference between my crt and plasma,not much.I am going to use this set until it dies.I will put it in my bedroom when I buy a plasma.
post #2007 of 11764
Keep in mind, the affordable plasmas today are all 720p, which your fully calibrated Sony will stomp all over. You have to get 1080p plasma - still VERY expensive - before you can begin to compete with the picture from fully calibrated 1080i CRT RPTV HD.
Mr Bob
post #2008 of 11764
I have a Phillips 46PP9302, it's overscan with the HD DVR over component (Motorola 1080i) is rediculous, well not really, just half the ticker on the bottom of the screen on say channels like ABC is cutoff, and sometimes the screen like judders and you can see the top part of the picture, like the overscan info and such.
I am guessing either some part is going bad or the overscan needs fixed. Also, on the same input with a progressive scan DVD player it judders on fast moving scenes and produces like a blue outline on people when it happens well not blue outline but it goes crazy and I see blue.
On 480p material from the cable box when there is widescreen material SD it has larger boxes on top and smaller boxes on bottom so I think the pixture just needs moved up and squished on the sides, some logos are cut off.
This may just be a problem with how the box does stuff as the regular NTSC tuner on the TV didn't have any problems.
Also, what is the difference between user menu multi-point convergence and the SM MP convergence. It seems when I go in the SM the convergence goes haywire on the sides, is this normal, and the lines in the MP don't line up correctly so I canceled and thought I would ask here. Also, I see geometry in the other menu but all it has is some wide something and the default number was 6 or 7.
post #2009 of 11764
Regular NTSC and HD are 2 different scanrates completely, using 2 different memory banks in your set. What your set does on SD as far as geometry goes, tells you nothing about what it does on HD/1080i.
Overscan is built in to every CRT based RPTV. It is a given. If you want it remedied, reducing it is easy. Correcting how badly the picture gets hosed when you do so, is where the talent comes in. It takes several hours to do this op correctly, and lots and lots of previous experience in doing so - or at the very least, a hell of a lot of intuition and puzzle-solving ability - to really get it right. The learning curve on overscan reduction is intense, to say the least. Don't expect a repair tech, or any calibrator whose only training is ISF certification, to have a clue.
Been awhile since I did a Philips, so would have to be inside the sm to be able to tell you anything, but one thing I can tell you: DON'T EVER PUNCH THE "DEFAULT" SELECTION! This would wipe out all setup work done by the factory and restore it to fresh-off-the-assembly-line status. You do NOT want to do that. Schlocky as the setup presently may be, it would be infintitely more haphazard and in need of professional attention if you wipe out all the work the factory has done so far, in setting up your unit.
Calibration prices are predicated on altering and improving upon existing, mostly reasonably coherent setups, from the factory. Start needing "from scratch" work, and the prices will go up noticeably, if not dramatically, depending on how badly everything gets mixmastered, in there.
I realize that not everybody will want to just fly me in. If you want to send me the current service manual info, I am available for phone consultation, on all things related to the calibration process.
Mr Bob
post #2010 of 11764
I realize this. I was just trying to help with the troubleshooting process.
So there isn't just some SM parameter I can change?
Heh, I didn't mess with it :P Everything is the same AFAIK.
Mr Bob
Not to try and hurt your feelings, but I am poor
I have just explored the service menu as the codes are readily available on the Internet.
I am guessing correcting overscan and vertical position is more of a mechanical job or advance SM procedures, if so I am not going to do it ^_^.
BTW, thanks for the advice/info.
  Back to Forum: Rear Projection Units
