AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic Plasma Problem
post #1 of 3
I have a TH42PD50 with a cable card. I've had it for a little over a year and everything has been fantastic. All of a sudden, on all non-HD channels, the right third of the screen is dark. I know that some sets have required firmware fixes, but I have no idea if this is the problem here. Has anyone experienced anything like this? How do I fix it?
Thanks...
post #2 of 3
Try the Self-Check Function :
Press VOLUME (-) button on The TV & SLEEP button on the remote simultaneously.
On the Screen Display, anything other that "OK" indicates a problem.
Press Channel + / - to exit.
NOTE: On the 60/600U Models The Self-Check function is also the factory reset. Not sure about the 50/500U Models so write down the pictures setting (if you need to) just in case.
post #3 of 3
Thanks for the suggestion... I will try it.
This thread is locked
