Originally Posted by RobertR1
Why have we not seen any movies even using BD-J menus upto this point?
- Talk
Originally Posted by Ja Phule
Amir,
MS has stated that they will not publish any 360 games on HD DVD. Is there anything stopping 3rd party developers from putting games or extra content on an HD DVD? |
Amir,
Originally Posted by Tom McMahon
10 bit baseband uncompressed source material has a higher bitrate than 8 bit material, but the compressed bitstream rate does not go up when coding 10 bit source (and depending on the bitrate and the content, it can go down!).
You are still coding 1920 by 1080 so the spatial part of the bitstream syntax remains identical. The frequency domain information is basically the same. The motion vectors get a bit more accurate, but their lengths remain about the same. All of that stuff gets entropy-coded by either CAVLC or CABAC as usual. I know that it's completely counter-intuitive, but the 10 bit bitrate does not go up. If the video was being run-length encoded maybe, but not with the H.264/AVC toolkit. To quote from one of Dolby's JVT contributions (JVT-L026): "These tests demonstrate that the quantization design for FRExt performs as intended – the rate-distortion depends almost entirely on QP. Sample bit depth only has an effect at low QP values where encoding at a higher bit depth always improves PSNR and often reduces the bit rate. Taken together these plots demonstrate that encoding at a higher bit depth is never more costly (in rate-distortion) than encoding at a lower bit depth, and is often more efficient." (QP is the "Quantization Parameter" , a codec setting that determines how coarsely the video is quantized. Low quantization = higher video quality, High quantization = lower video quality.) The JVT source-code reference encoder supports 10 bits and has freely available to everyone for the last several years (that's how everyone verified each other's work during the development of the High Profiles (FRExt)). You wouldn't want to use this encoder for any real world production, but it serves as an excellent starting point for anyone building real product for the blue-laser marketplace. |
Originally Posted by DaViD Boulet
Amir,
I heard that the new firmware fixes the "720p bug" in the A1. Question... is the player bobbing to 540P then converting to 720p with the fix or applying IVT/3-2 reversal in order to get a proper 1080p frame to downconvert to 720p (I'm assuming not). thanks! |
Originally Posted by DVDoctor
A few questions if I may:
With PS3 offering a model without HDMI and possibly the HD DVD add on for the X box 360 also haveing a version without HDMI are we seeing a move away from this being a required part of the BD/HD implimentation? |
Originally Posted by TheLion
I take it that the video decoder chip of the HD-A(X)1 is not able to actually decode the 1080p/24 content on the discs as such but adds 3:2 pulldown and outputs just 1080i/60.
In theory this doesn't/shouldn't matter much - but in the real world it actually does: 1) From the technical point of view you need to "deinterlace" (inverse telecine) the 1080i/60 stream in order to display it on a progressive display device. That has to happen at some point. Problem is there are VERY few video processors/scalers and even less display devices out there in peoples homes that do a proper job (read: restore the full vertical resolution of the 24p source and not just "bob" the "interlaced" stream) with that. When you are lucky and have a device that allows for proper inverse telecine it is still not a very elegant solution to go the 24p content->60i decoding and output->24p/48p/60p display route. 2) Sony has a (stupid or not so stupid, see above) marketing weapon with this whole 1080i versus 1080p issue. You hear BB employees convincing Joe Six Pack that BluRay is the way to go BECAUSE it is 1080p and HD-DVD is not. You read USA Today articles claiming that BluRay is the more advanced format BECAUSE it is 1080p. You even see alot of confusion around here at a so called enthusiast forum regarding this matter. Sony has done a marvelous job of making the general public believe that BluRay's 1080p "support" is vital. They even obviously made Samsung integrate an extra "deinterlacing"/inverse telecine chip into their BluRay player just to keep the 1080p argument and marketing buzz going. Now on to my question - Is the hardware design/SoC that allows native 1080p/24 decoding and output (without any inverse telecine step in between) already available and ready to use for a next generation Toshiba player? Or is upcoming PC HD-DVD playback going to be the only solution for "real", native 1080p/24 decoding for the time being? |
Originally Posted by richard plumb
would the region be tied to the drive, or to the host player? eg if I (as someone from the UK), bought a US HDDVD drive would it
1) Work at all ;P 2) let me play US DVDs, while my main drive played R2 DVDs. |
I have a general question: People use the term "pulldown". Does anyone really understand what that means?
(This is a trick question of course; We know the answer.) |
Originally Posted by AnthonyP
Amir or anyone in the know for HD DVD
what is IME (is it PIP and the audio that goes with it or does it also include subtitles and menus ) does IME have a max bitrate (and what is it) or does each part have their own limits (IME video can't be longer then X, audio can’t be higher then Y....) |
Originally Posted by stoked
Furthermore, these HDCP compliant video cards only have SPDIF passthrough, so even if Intervideo or Cyberlink HD-DVD/Bluray software decoded the TrueHD/DTS-HD soundtracks into 5.1 LPCM, how do we get the 5.1 LPCM to our receivers? SPDIF doesn't support 5.1 LPCM as far as I know.
I cannot comment on how CE companies use our chip in any given product. But if they want to achieve 24P that is possible.
Insiders,
Thanks for all you discussion. I'd like to bring up HTPC's as they have not been discussed much. With the HDCP enabled video cards just starting to show up on store shelves I'm curious as to how Dolby TrueHD/DTS-HD will be handled on the PC. I saw a Realtek slide that showed without "content protection" audio will be downsample/mixed to 2ch 16/48. Does this mean in addition to a HDCP video card, us HTPC users will require a soundcard that supports "content protection" in order to listen to TrueHD/DTS-HD? Furthermore, these HDCP compliant video cards only have SPDIF passthrough, so even if Intervideo or Cyberlink HD-DVD/Bluray software decoded the TrueHD/DTS-HD soundtracks into 5.1 LPCM, how do we get the 5.1 LPCM to our receivers? SPDIF doesn't support 5.1 LPCM as far as I know. Also, is there any ETA as to when we may see HD-DVD or Bluray PC drives? Thanks again. |
Tom, thank you for your reply. Please allow me to dig a bit further...
Does your BCM7411D chip (used for video decoding in the Toshiba HD-A(X)1) support NATIVE 24p decoding and output if CE companies choose to use it? |
Looking at the product brief at your webpage does suggest otherwise (1080i output).
And it is my understanding that the Samsung BluRay player has to use an extra deinterlacing/inverse telecine chip in order to provide 1080p output with your chip.
Please understand that this is a real issue - it is not just about displays that don't do proper 1080i "deinterlacing". It is also about all the new and upcoming displays which support/show 24Hz content at its native rate (or a multiple of it like 48Hz, 72Hz,...). I cannot think of a single one of them that does proper inverse telecine -> if you feed them 1080i/60 (as the BCM7411D based Toshiba does) they will show it at 60p -> with 3:2 pulldown judder! But if the input signal is 1080p/24 they will show it at a multiple of its native rate -> judderfree! And you will agree with me that THIS is a real revelation and the only way to go.
As much as some people try to make us believe that the 1080p BluRay argument is pointless marketing buzz - in reality it isn't because proper 1080i deinterlacing and inverse telecine is more an exception than a given in the market place today. Even if some day our display devices and video processors would support proper processing - isn't it just the most natural thing to decode and output progressive 24Hz content at its native rate? "Word is" that the BCM7411D chip is not able to do it.
Thank you very much for your time and sorry for the uncomfortable questions asked!
...While the main program film content is *always* progressive (to answer another question on this list), the PiP channel may in fact be interlaced (unfortunately). This creates a situation where the player must comingle progressive and interlaced streams (not to mention presentation graphics etc.).
There is no easy way out of that box - once you introduce interlace, with it's spatial and temporal screwups, you're dead meat. And if you want to output progressive after that, you *must* deinterlace... |
pip and "features" comingled with primary 1080p video streams should *always* be converted to the primary feature's frame-rate prior to merging. IMO all playback hardware... HD DVD and BD... should be designed this way regardless of disc-encoding strategy.
If I select 1080p24 output from my HD box, that's what I should get when watching a 1080p24 movie... regardless of the pip mode for Peter Jackson's commentary. |
