Originally Posted by mrzippy2000
Amir,
Do you know if or when Vista Media Center will record tv using the VC-1 codec?
No it will not. As you know, the current US standard for digital TV is MPEG-2 so the system simply records that stream unchanged. For analog TV, it could encode in VC-1 but given the MPEG-2 encoder on the card, that is the format used. However, there are third-party converters which in the background, transcode the MPEG-2 streamst to VC-1 so that you can for example, create smaller files to take with you on a laptop.
| How much more computer power will be required to encode the signal in realtime vs. the current codec? |
For standard definition, modern PCs can do that in real-time. For 720p, a dual-core, dual-processor systems should do the same. I don't have a good feel for 1080p right now (or 1080i60 which is even more difficult).
It seems the advantages of smaller file size and bandwidth would make it an ideal solution for Media Center.
Scott |
It would :). I hope such a solution comes to market some day because it also allows easier streaming around the home due to lower rates.
