AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › Industry Insiders Q&A Thread: only Questions to insiders please
Industry Insiders Q&A Thread: only Questions to insiders please - Page 24
post #691 of 4623
Hal, I a sorry for lack of reply. I have been thinking about the points being made some of which was just mentioned by the Tom and Tom. And was hoping the hardware folks would be fielding the question.
Anyway, the problem is actually rather complex. HD DVD can have three sources of content, all of which has to be mixed together: primary video, PiP and graphics. All three could run at different rates/resolution, up to 60i. The easiest path therefore, is to "upconvert" all to 60i and then have a mixer. Since all displayes have dual mode de-interlacers (i.e. can do the simple inverse telecine or proper de-interlacing of 60i sourced content), there is little harm in this. Send out straight 60i and the display will then just do the simple inverse telecine if that is all that is needed. Send it a complex one with 24p main video (converted losslessly to 60i) with inset video of 60i and the display can do the proper motion adaptive de-interlacing and still get you a pleasant picture.
If you want to output 24p, then you have to convert everything down to this. To do this well, and not butcher the PiP, you would need to good de-interlacer which is the solution used in Samsung and Toshiba recorder in Japan. You don't want to do a bad job here because if you do, the damage done, can not be undone. Whereas in the 60i case, you don't suffer from this.
So in an odd way, 1080i may be superior to 1080p24. This is why I and some others have talked about 120hz output at some point, which is a nice multiple of both 60i and 24p and does not require repeating fields.
And yes, as Tom mentions above, there is no assurance in the player that you can just do the inverse telecine (at least I don't think there is). So while in BD players which for now, don't support PiP, the case is simpler as far as outputting 1080p24, I think they face the same problem. Maybe Keith can say if any of the BD players based on their platform support 24p, or they also resort to same technique as Samsung/Toshiba....
Note that I am not 100% sure my explanation and understanding of the issues is correct. I think I am close but I am still doing a bit more research on it. For now, let me say that Kevin on my team, is a happy camper, running his Toshiba HD DVD player at 72 hz, driving his CRT projector. Of course, he has a high-performance GPU to do rate conversion for him of the inset video, but there is good existence proof of "24p" output from HD DVD already.
Hope this at least provides some of the key data points until we get the definitive answer.
post #692 of 4623
Originally Posted by RealEstateWagon
Kevin Collins said that in the future you will be able to download new HD trailers to your persistent storage on the HD DVD player. This I can buy.
Great :).
He also said that you might also be able to download a director's cut. How is this possible? Will the HD DVD player read from the HD DVD disc and then jump to the on-board memory to read a new scene, and then jump back to read from the HD DVD disc again?
HD DVD has specification for an alternative track, called S-EVOP, which can be stored outside of the disc. Then the menu system, iHD, can call upon it and stich it with the rest of the movie. Note that this other video has a data limit of 15 Mbit/sec so it would have to be an advanced codec to support HD well.
So iHD takes care of telling the player which segments to play and in which order. In other words, it is no different than having a playlist in Windows Media player with different tracks coming from different parts of your machine including the network.
post #693 of 4623
Originally Posted by amirm
Great :).
15Mbit/s for the peak or avg? Could this other video overlay the main feature as PiP?
Could this 15Mbits/s all used by a lossless external sound track? If so, then HD DVD may have a bandwidth of 45Mbps?
post #694 of 4623
Oh, I'm sure you weren't expecting this follow-up, but here goes anyway:
Can you please elaborate? :D
post #695 of 4623
On which part? Or are you pulling my leg :)?
(running out to drive up to LA from San Diego so may be out of pocket until late tonight after the LA AVS Forum HD DVD meet)...
post #696 of 4623
I bolded the part in my original post; does Kevin have some special version of the Toshiba HD DVD player?
post #697 of 4623
I remember he use an HTPC to play HD DVD.
post #698 of 4623
Amir,
Thanks for the response. It sounds like PiP is what's causing some of the complication, then. Well, I guess Tosh needs to put a better de-interlacing (or maybe scaling) solution the box, then, as all reports seem to indicate it's 720p output is sub-standard compared to 1080i. I really don't want to depend on my display to do the conversion.
Sorry for badgering, but this information was so different from what the impression I had I wanted to see if l could get it straight. Maybe some of the other insiders can add to this.
One more thing, is the PiP part of the problem always present, even when not in use (I'm assuming yes)? So just by turning off PiP I still wouldn't get a better progressive signal?
Be interesting as well to see how this plays out for BD once they get PiP going.
post #699 of 4623
The laptop? That's a player with the high end GPU. And 72Hz is a common enough refresh rate.
Gary
post #700 of 4623
How about 600Hz? Then we can do away with all those pesky 50Hz/60Hz issues too. :)
That schism remains, and continues to complicate things. I wish line frequency stuff had just gone away, and the standards had been defined at 24/48/72 Hz for all.
Gary
post #701 of 4623
Originally Posted by Enigma
Amir,
as all reports seem to indicate it's 720p output is sub-standard compared to 1080i..
I belive there is some confusion on this. On the ha-a1 the displayed numbers 480,720,1080 are refering to the resolution of the imput.
all output over HDMI is 1080 thus
480 to 1080 sd disks
720 to 1080 (no disks yet avaiable)
hd to 1080 HD-DVD disks
I belive I have this right
post #702 of 4623
Originally Posted by trbarry
I think the problem is you can only use the "relatively simple-minded process that only takes a state machine" under those conditions where you are already certain that you have pure telecined 24p material.
Those conditions would include the overwhelming majority of HD-DVD titles, since they're encoded as 24p on the disc and it's the player doing the telecine in a very consistent way. It's not like SD DVD where the telecine is done before storing the material on disc, often inconsistently, and can vary from scene-to-scene.
Steve
post #703 of 4623
While the various audio and video mixing options in HD-DVD are interesting, I think they're also creating a drag on the format because people don't understand how it affects the ability to output Dolby Digital, 1080p24, etc. It would be really great if future players could have some sort of "pure direct" mode that would just take a single audio track and pass it through without decoding or mixing it, and also take the video and pass it through at 1080p24 without PIP or any other video overlays.
Steve
post #704 of 4623
Talk,
A few questions if you could please answer them:
Since you work on BD-J:
1. When will PiP be supported?
2. Players that are out before then, will they be firmware upgradeable to use the PiP features?
3. When will BD-Live see the light of day?
Other questions since you're an insider:
1. When can we expect to see 50GB media?
2. What percentage of the titles will use 50GB media?
post #705 of 4623
Originally Posted by dr1394
The 1080i@29.97 video bitstream structure of HD-DVD prevents decoders from generating 1080p@23.976 output. Although the telecine flags may describe a perfect 23.976 coded pictures per second on current HD-DVD movies, there is no specification (MPEG-2, VC-1, H.264 or the HD-DVD specification itself) that says this must be so. In fact, the telecine flags can describe a bitstream with any amount (between 23.976 and 29.97) of coded pictures per second.
Because the telecine flags are variable, the decoder cannot ignore them and hope to properly decode all legal 1080i@29.97 bitstreams. The decoder must pay strict attention to repeat_first_field and top_field_first flags. Therefore, for HD-DVD the decoder will always output at 1080i@29.97 by repeating fields as instructed from the 23.976 coded pictures per second on the disc.
1080p@23.976 output from HD-DVD is a non-starter. However, 1080p@59.94 is definitely possible from the next generation of HD-DVD players with the inclusion of a deinterlacing chip (like the Samsung Blu-ray player).
Ron
Ron is both right and wrong.
He is right in that all of the issues he mentions are possible. He is wrong in saying that you can't ingnore the flags and output 23.976.
The SD DVD version of InterVideo's WinDVD does this. It sends 23.976 straight to the video renderer in Windows. If you watch something like the x-files, then you get a mess. If you watch something like Star Wars Episode III, then you get a clean image. The HD DVD version of WinDVD does the same thing. I am able to do this today on the Toshiba laptop.
In an interesting way, a lack of a feature in the current VC1 encoder for BD and HD DVD makes this more robust. We have not implemented inverse telecine in the VC1 encoder. So we don't have real mixed mode support. This means you must send a 24p (or 23.976) source into the encoder. This ensures that there are no flag errors on the main feature. If you have mixed content, then you encode it as interlaced.
The problem you will run into is when you try and play back IME or bonus features. That will look ugly. IME may also cause problems for any device doing inverse telecine. It is running at a different rate than the main feature.
BD made the wiser choice. Even though displays now support inverse telecine for 1080i, those algorithms still drop lock when they think a cadence error occurs. With a true 24p out, there is no chance for this to occur.
Of course there are two BD players this year that output 1080i from the decoder and use a 3rd party chip to convert to 1080p. The first is the Samsung, the second will be out in a couple of months.
The biggest problem I see with 24p in the now is displays re-syncing as the output switches between the various rates.
post #706 of 4623
@amir, or any other insider that might know:
do any of the current/forthcoming titles make use of "side information" in the encoding process? if so, to what extent?
is the current gen Toshiba player equipped to use this information?
PS amir, you haven't answered the question that you asked people to ask you, which title will be the first avc encoded hd dvd title in usa???
post #707 of 4623
Originally Posted by sspears
[a] BD made the wiser choice. Even though displays now support inverse telecine for 1080i, those algorithms still drop lock when they think a cadence error occurs. With a true 24p out, there is no chance for this to occur.
[b] Of course there are two BD players this year that output 1080i from the decoder and use a 3rd party chip to convert to 1080p. The first is the Samsung, the second will be out in a couple of months.
[c] The biggest problem I see with 24p in the now is displays re-syncing as the output switches between the various rates.
stacey,
[a] when you say BD made the wiser choice, i am a bit confused; are you saying that hd dvd CANNOT also output 24p (not talking about the current gen tosh player, but any future player that is designed accordingly)...are you saying this is not permitted/provided for under hd dvd?
[b] since sony is delayed to october, do you mean the pioneer or the panasonic is employing the same design choice as the samsung; i.e., to use a deinterlace chip?
[c] do you mean if there is mixed content on the disc, like 24p as well as 30/60i? that would be a nightmare on any of my current displays as they don't re-sync very quickly.
TIA
post #708 of 4623
...He is wrong in saying that you can't ignore the flags and output 23.976...
So the question for the Toshiba HD-A1/D1/XA1 & RCA player is; can the Broadcom chip ignore the flags and output 23.976?
Does the Toshiba hardware design allow a "Pure Direct 24p Film" output possibility via a firmware change?
Allow such a possible optional user choice with the user knowing/warned that it messes up IME and any extras that are not sourced as 1080p/24?
Bob
post #709 of 4623
I would second the further explanation of why BD made the wiser choice.
I'd also add that if you're bothered about 24p output you'll probably not want to mess it up with interactive stuff... If having two play modes 'Direct 24p' and normal is the compromise then I'd be happy.
Ian.
post #710 of 4623
I'm not an insider, but I'm with Stacey on this one. As I asked in one of the threads were this was discussed here:
http://www.avsforum.com/avs-vb/showt...&&#post8030782
Originally Posted by darinp2
So, for somebody who claims that HD DVD cannot have a 1080p24 mode that the user can select, I would ask:
"Can TheaterTek or the Lumagen scalers do 720p48, 720p72, or 1080p48 with film content? If not, how do you explain all the people using them one of those ways?"
There is a difference between not being about to give the user an option and there being cases where the user would want to disable it.
--Darin
post #711 of 4623
Not to challenge your technical skills, but I read Ron's comments differently. After looking at the HD-DVD requirements he cited, I believe what the gist of his comments were that you couldn't ignore the flags and still be "legal" (as in compliance) to the documented HD-DVD spec. Yes outputting at 23.97 is possible, but only if you choose to ignore the spec and it's requirements as they are currently defined.
Key Performance Requirements:
1) In the case of 60 Hz region, 3:2 pull down flag is mandatory for movie (film content), which means that synchronization between video, audio, sub-picture, and advanced objects follows 60 Hz vertical synchronization signal.
Again, this is not to question your analysis, but to put it into a different perspective.
b2b
post #712 of 4623
Wow...there went three hours of my life :)
Q: When do folks expect to see a DIY HTPC solution for either HD DVD or Blu-ray in the United States?
Just stating a CY Quarter when you expect things to come together for either format would be great to know, I know you can't share what particular companies w/ particular products are doing what when.
post #713 of 4623
Amir,
Question about VC-1 encoding, excuse me if it has already been answered.
When you put the master data trough the encoder I'll guess, there is more to it than just hitting the "Encode" button and later a 100% quality HD DVD pops out at the other end. How does it actually work? How many man hours does it take in average to encode a HD DVD?.
(By the way i just came back from a photo session tour/vacation in Grand Canyon with my Canon 20D :) - that place is amazing)
Thanks for your time - I really wonder how you can find spare time for this - just fantastic!!
post #714 of 4623
Moderator's kind reminder..
In this thread, make sure you're either asking a question of an insider or you are an insider responding to the question. See the first post.
post #715 of 4623
I have a feeling that it's the one he's showing tonight at the meet-and-great.
post #716 of 4623
Originally Posted by J.Mike Ferrara
Why can't Warner release V for Vendetta a week early than the SD release??
Amir,
Could you keep this idea in mind for future releases? If your involved in any meetings or so on with studio execs. This might be a potential marketing idea (if it hasnt already been discussed and shot down). I bet it would be a huge draw.
post #717 of 4623
Wouldn't you need a 120 Hz display that can accept a 1080p120 signal for that to be possible?
lymzy, remember that the required HD DVD buffer is 140 MB and because HD DVD is a random access format you would have to store the entire soundtrack to the buffer. Even excluding that issue how would you get the entire audio track into the buffer? Finally how would you sync the audio track with the video track?
post #718 of 4623
PiP will be supported in players supporting BD-Live, which I expect to be supported by the PS3 and all 2G players (but will have to be announced by the respective player manufacturers). While I believe PiP could be supported by all BD players (that is, I believe the hardware to support it is already present), it would be up to an individual manufacturer whether to enable support outside of a fully BD-Live compliant player.
I certainly expect to see them this year. I imagine it'll be a very small percentage this year (perhaps 5 or 10% of new titles introduced), with the number rising slowly as manufacturing costs drop and the creative community finds interesting ways to make use of the added capacity.
Note that these are purely my predictions; I have no concrete knowledge of plans related to these questions.
- Talk
post #719 of 4623
Unfortunately not. That title is from Paramount and we don't have permission to use their content for tonight's meeting.
BTW, this AVC title is not the sign of things to come. It is the sign of things that have come and gone :). This was the first title encoded and after that, they switched to VC-1 and they are quite pleased with the encodes....
I have provided another hint on this topic if you are dying to know which title it is in some other thread (yes, you have to work hard for it :D).
post #720 of 4623
Originally Posted by RockStrongo
Amir,
Unfortunately, the area that we have next to no influence in is the titles. That is a purely business decision for the studios and we try to not poke our nose in it. Lest we want them to tell us how to design VC-1 :).
  Back to Forum: HDTV Software Media Discussion
This thread is locked
