AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Accessories for Panny 600u
post #1 of 3
All,
Just bought my Panasonic 42px600u and I need your help in buying the accessories to go with it. The existing equipment is -
Television: Panasonic 42px600u
Home Theater: Bose Lifestyle 800 series
DVD: JVC XV-421 and DeSay DS-5701
I assume that these peripherals are pretty old, but with this configuration, what hardware/accessories/cables would you recommend for an optimal experience?
What surge protector should I consider? Will HDMI/Composite/Component work with these peripherals?
I do not have Cable/Direct TV yet but lets assume I go HD soon.
Thanks for your help!!!
post #2 of 3
Look at Monster Cable surge protectors, for a start. They are a little pricey but seem pretty solid. I am getting an HTS 3500 mk II.
For an optimal experience, first find out whether your DVD player is a progressive scan or not, if not you will want to update that so it will give you the best quality video.
post #3 of 3
Thanks, will check out monster. My DVD is progressive scan. I assume I will need to go with composite cables for now.
This thread is locked
