Originally Posted by recoil
So I got my U-Verse installed today and am pretty pleased with the picture. For the HD shows that I typically watch on Monday's, I watched them on my DirecTV and then on U-Verse, and they pictures looked really close --- hard for me to tell a PQ difference.
Now I think with Sports, that may be another story, with all the motion, but we will see how that ends up.
One thing I DID notice, was that the U-Verse picture seemed darker a bit. Now it goes into my TV via the same HDMI input as my DirecTV and Blu-Ray player, and I did calibrate the TV for that. But the HDMI out of the U-Verse did seem a bit darker.
Are there any "advanced" tricks that can be done to tune the color of the U-Verse DVR on the HDMI port to help calibrate it? I thought I read somewhere that someone had dome some tweaking on the HDMI for U-Verse, but I can't remember where I saw that or how it was done, or what recommended settings may be.
The UV STB outputs 0-255 for color over HDMI most TVs prefer 16-239, if you can adjust your set to handle 0-255 it will look better otherwise it will crush the blacks. Many people use the component output which does not appear to have this problem.
. I lost the full series of the Discovery Channel's "Life". The tech wasn't able to tell me what happened. I don't know if what you're experiencing is the pre-cursor to what happned to me. Good luck.
