AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung 71' 1080P DLP HL-S7178W (owners)
Samsung 71' 1080P DLP HL-S7178W (owners) - Page 31
post #901 of 1718
Originally Posted by ethereal45 View Post
I called Vanns -- they will take it back if it's truly defective until next friday (15 days after delivery), but it sounds like one bad fan doesn't constitute a defective tv. We'll see what the repairman has to say when he comes (hopefully asap).
Ethereal, I am sorry to hear you are having issues OTB. I am sure they will get you squared up and happy soon.
post #902 of 1718
Yeah, I'm really really disappointed. Nothing more than some bad luck I suppose. I'm having the TV shop that Samsung authorized for the warranty repair come out ASAP to determine if it's a minor problem (hopefully) or if it's a defective unit.
If it's major I'll definitely make sure Vanns replaces it, if it's minor then hopefully a simple repair is all it needs.
post #903 of 1718
Yikes, I suspect shipping it back is gonna be a major hassle...
post #904 of 1718
Yeah, it would be a huge hassle. If it can be fixed I'll go ahead and have it fixed. I will however be calling Vanns to see if they will give me the extended warranty.
post #905 of 1718
Hello everybody,
Finally got my new light engine installed which fixed my previous problem but now i see a really small black spot on the screen (looks like a piece of lent or dust) that probably nobody would notice but me but my eyes seem to be glued to it and it feels like it is growing..
I dont know whether i should call and have them come back out to fix a piece of dust or whatever it is that got in there or just leave it like it is and be happy the tv works and doesnt shut off. Im just so frustrated that i cant get everything perfect but am i just being too picky?
post #906 of 1718
Originally Posted by Busacrazy7 View Post
Hello everybody,
Good to hear the light engine was fixed. It's a new tv and you spent good money for it and you should be happy with your purchase. If it was my set, I would see what's involved with correcting the problem. If it involves having to diassemble the screen glass to clean it, you will have to decide if it's worth the hassle and if the service people are up to the task. Swapping the out light engine is a relatively easy job compared to taking apart the screen imo.
post #907 of 1718
Are dust spots or little things of that nature common. Where would the dust/dirt be? Cause it wasnt there before the light engine swap so im guessing it got in there during. Is that something i can do on my own or should i call the tech. I watched the light engine swap and i could of done that in my sleep...
post #908 of 1718
Spots, smudges, etc. probably occured during the assembly process. It has been mentioned in other Samsung threads. And you probably could do this yourself but it will/may require the assistantance another person to handle the screen. One of the calibrator dudes wrote in depth, the procedure. Search it. But if the spot wasn't there prior to the light engine fix, call the service people and have them fix it.(?)
If you should ever need to have the light engine replaced in the future, and you do it yourself, you just saved about $400!!
post #909 of 1718
Hey All,
I am joining the family on 7178 owners, and I am super-pumped about it. I was thinking about buying around the Superbowl, upgrading from a Mitsubishi 65905 (bought in Jan 2001, it only does 1080i thru one component connection on the back). Found an awesome deal online for $3300, so I promptly pulled the trigger and also got a 3 year extended warrenty. The set is suppose to arrive next Wednesday as a late Christmas present for me.
How long should I wait before having it calibrated? Anyone know a good calibrator in the Northern California area?
Don
post #910 of 1718
From the threads I read 50-100 hours of use. Mine is also due in on Wednesday. Just a note, you may want to edit the pricing info. They fround upon that sort of stuff here. Good luck with your new set.
Gary
post #911 of 1718
Originally Posted by hearth View Post
Hey All,
Don
Welcome to Team 7178!
$3300 shipped? Great deal.
The usual waiting period before calibrating is about 100hrs. David of avical is one possiblity. UMA(Jeff) travels to Ca. There others as well. I'm leaning towards having UMA tweak my 7178. He has a Samsung hlsxxxx, I believe.
post #912 of 1718
Wait long enough to be sure you are not going to have an early failure.
Northern California is a big area. UMR and David Abrams travel through Northern California on a regular basis. Check the owners list that is linked at the bottom of my post for information. You can contact them or any other calibrator that's a member of AVS from information in the list.
post #913 of 1718
Jeff's user name is UMR and he has a Samsung HL-S6188 which is the same light engine as the HL-S7178. David Abrams has an "88" model too.
post #914 of 1718
I am going to OWN one of these 71" Beauties by the end of March........
post #915 of 1718
Hey All,
Don
hearth
Congratulations on joining the list of 7178 owners! In terms of a calibration... You will want to wait approximately 50 hours of use or several weeks. Basically, you will want enough use on the display to know that it isn't a lemon. For the most part, we have found that if there is an issue with the display it usually presents early on; however, that doesn't mean that something can't go wrong later down the road - let's hope not though .
We regularly service the Northern California area and would be happy to assist you with the calibration of your display device. For more information/details please visit our website.
Dave
post #916 of 1718
Originally Posted by RockStrongo View Post
My avical review...
I obviously have a Samsung HLS-7178W DLP rear projection set. I have a series 3 tivo (hd dvr with cable cards) and toshiba a1 hd-dvd connected via hdmi inputs. My Xbox 360 is connected via component.
I calibrated the set initially with DVE, but knew that I needed more. So, I researched here and chose avical to do the calibration (David performed it). I did so based on the reviews here. Thanks everyone!
I knew the change would be good, but not as drastic as it was. It was a night and day difference on my sammy. HD broadcasts look ALOT better now. I dont see as much pixelation (usually due to broadcast compression) and the colors are dead on (when before I was never completely satisfied).
A big change in my opinion was the grass during football games (fleshtones were another issue). I was always tweaking the user menus to get an accurate color, but was always slightly disappointed. After the calibration, it looked completely accurate.
The changes to the xbox 360 and hd-dvd were more evident on color temp and black levels. The black levels and color are super! I popped in Batman Begins and I must say, it was astounding.
I cannot recommend avical more highly. Im a perfectionist when it comes to picture quality and my expectations definately were exceeded!
Along with probably being some of, if not, the best in the country at video calibration, they are hella nice guys too. Im sure ill be using them for years to come.
Thanks to David and Eliab!!
[b]RockStrongo[/b}
Thank you for your kind words. We are happy to hear that you are enjoying your calibrated system. One thing that will make your experience even better, would be to sit further way .... But you already know this. Let me know how the move goes and how the theater comes together .
Best,
Dave
post #917 of 1718
Is there a way to tell how many hours you have on your system?
post #918 of 1718
Problem........
Turned it on just now and the set did not brighten up like usual. The picture was there but very dark. Interestingly 1" from the top right coner is a bright picture. It's almost like something is in front of the lens.
post #919 of 1718
Could possibly be a collapsed light engine tunnel. If that's the case, it's an engine replacement (covered under warranty).
post #920 of 1718
OK...I'm not an owner yet...and I haven't quite figured out how these threads work, so I'll take a chance and post here.
I've been checking out 60"+ tvs, and was just about ready to pull the plug on the 65" Panny Plasma...BUT, after walking through a local store, my husband fell in love with the Sammy 71" DLP. Since he's taken no interest so far, this was quite a coup. Needless to say, after reading every comment in this thread, I'm ready to pull the plug. Will probably do so in mid-January.
Just wanted to thank everyone for their input in this thread...I'll post back once I am a real "owner."
post #921 of 1718
letjet,
Send me an email and I'll walk you through it.
Dave
post #922 of 1718
Hello, new to the thread and have a PC port/Xbox 360 Question. I just picked up my HL-S7178W two weeks ago and immediately changed my 360 to a VGA input. I also received the 360 HD-DVD player a couple of weeks prior. My problem is that the blue levels (and maybe green) are too high when watching DVDs and HD-DVDs. It is very apparent on white and grey surfaces on screen. I've used settings other people have posted on this thread for their 360s, but they may be using the component input, as this has made no difference. Changing modes to change color tone has also had no effect, nor has raising the red setting in color weakness. Any suggestions?
Bradrcr
post #923 of 1718
You may have tried this already...but I find I get much better color with the TV set to "Text" when running the 360 with the VGA cable. This is currently on an LCD, so may not be the same on the Samsung.
post #924 of 1718
Sorry, text is not an option. However, I did go into the service menu and raised the blue gain to 164. Seems to have done the trick with some other fine tuning in the standard menu.
post #925 of 1718
Before making any changes, I would have made sure that the cable was making good contact. The voltage for no color input is 0.0V to 0.6v for max color. A little "dirt" on the contacts have a profound effect on the display.
Carl
post #926 of 1718
Hi all,
Got my 7178 a week earlier than expected (due to a shipping mistake that actually went in my favor for a change!!). I spent almost the entire weekend getting my system and am thrilled so far with it. I got alot of complements with the extended family over this morning.
One issue that I am having so far is that I am getting a green line on the left side of my screen with my Panasonic DVD recorder hooked up via the HDMI2 port. Does anyone have an idea what might cause such an issue?
By the way, thanks for the recommendations on calibrators! I live in the Sacramento area and will be contacting David in a couple of months...
Don
post #927 of 1718
After your calibration, I am able to sit about 2-3 feet closer. Now, im about 4-5 feet from the tv.
jk
post #928 of 1718
I'm having a little problem with this set and was hoping that someone has a solution... Every once in a while when the set is on (maybe 2-3 times an hour) I get a loud cracking noise coming out of the back of the set. It sometimes happens within an hour of turning off the set. This has been happening ever since I got the TV and I thought that maybe the plastic is expanding from the heat produced from the bulb and it will eventually settle. Two months have passed...No change.
I tried loosening the screws for the pack panel, thinking that maybe the panel needs more freedom to expand, but still no change.
I removed the small plastic stand on the bottom of the set when I first got the TV. Is it possible that this caused it? Anyone have any ideas?
Thanks guys. Appreciate all the help and info I got from this thread.
post #929 of 1718
It will likely continue to happen. What you are hypothesizing is true - the plastic is flexing with the internal heat, and that's causing the popping noises. Unless it's affecting the image you're seeing on the screen, or producing some sort of "burning electronics" smell, I would not worry about it.
post #930 of 1718
No the TV works great and there's no burning smell (or smoke coming out of the back )
I guess I have to live with it. At least now I know nothing's wrong with my set. Thanks rnick.
  Back to Forum: Rear Projection Units
