I have now tested three Westinghouse LTV-32w3 tvs and they all have the same problem: a band of lines on the left side of the screen via the DVI port. I have tested this with two completely different Dell computers with different video cards, and a Apple Powerbook. I've even tried some custom resolutions (1368x768.. no luck) I have also tested this with a Motorola Voom satellite receiver (TV won't even detect this input source). The only thing I don't have access to right now is a DVD player with DVI out. I have tried different DVI cables. VGA input works fine.
I've called Westinghouse and they have no idea what's causing it.
I have the previous generation LTV-32w1 which works fine with all DVI inputs.
Could West have messed up the DVI inputs on this model due to the new HDCP standard?
Chances are high that this thing will have to be returned (sigh).
Someone here on this board had the same issue, and got a replacement that worked. the replacement had an older firmware (not the April 06 one)
Any ideas?
Any ideas?
