AVS › AVS Forum › Display Devices › Rear Projection Units › The Official Sony 2006 KDS-(XX)A2000 [NO PRICE TALK] SXRD Owner's Thread
The Official Sony 2006 KDS-(XX)A2000 [NO PRICE TALK] SXRD Owner's Thread - Page 341
post #10201 of 14227
Has anyone had problems with the speakers on their tv popping?
My 50A2000 began popping & cracklin a few days ago.
Any suggestions?
post #10202 of 14227
Has anybody tried putting a center channel speaker on top of this TV? The top of the TV is far too thin to support my current center channel. I'm thinking of just getting some kind of scrap wood and carving out some makeshift supports for the speaker so that it can stay up there without fear of falling down. I was just curious to see if anybody else has ran into this and came up with any other solution.
Unfortunately the center channel speaker will not fit in the Sony stand either so that's not an option.
post #10203 of 14227
Try this... http://www.target.com/gp/detail.html...sin=B000BQU00I
...Or, better still, this... http://www.standsandmounts.com/index...OD&ProdID=3917 Worked like a charm for me.
post #10204 of 14227
Perfect! Thanks for your help!
post #10205 of 14227
I have my Center channel sitting upright behind the TV. there is about a 5" space btw the bookshelf wall and the edge of the TV to allow the sound to come out. We have not noticed any loss of sound quality by this setup and my wife has a musical background that can hear things that most others can't. The set up also keeps the L-C-R speakers in a straighter line which is suppose to give you a better sound field per some articles that I have read.
Brett
post #10206 of 14227
I'm having absolutely no luck getting my tv to display an image from my computer. when I first connected my computer to my 55A2020 via DVI-HDMI my desktop was displayed on the screen but with an extreme amount of overscan so I downloaded powerstrip, installed and reloaded my pc. That's when the SXRD stopped working with my pc, it now says "unsupported signal, check device cable". So I plugged my dvi cable into my little Samsung monitor and everything came up fine. I even uninstalled powerstrip thinking that was the problem, but the SXRD still does not show an image from my PC and the same error message appears, even when I try the other HDMI port on the back of the tv. I connected through the VGA port but as we all now, the resolution is hampered on that input with our tv. I would like to get my TV back working with my pc like it was originally, but it now refuses to do so! I'm stumped! graphics card is an ATI Radeon 9800 XT. Buying a new graphics card is out of the question right now, I'd be more interested in returning the TV for one that works at this point. I have about 3 weeks of a return policy left. Please help!
post #10207 of 14227
Originally Posted by 07pilot4me View Post
posted on 2020 thread, but since these tv's are the same thing i will post here too
hi all,
just pulled the trigger on a 50a2020 sxrd
now shopping for dvd players, here are my choices
oppo 970hd
oppo 981hd
toshiba hd a2
toshiba hd a20
i'm considering the toshibas since they are nearing the price point of the 981hd. i will be playing mostly movies on dvd+r/dvd-r discs. since the toshibas upconvert as well, i was thinking why not.
does anyone know if the 50a2020 has a good deinterlacer?? this seems to be the question most asked on weather or not i need 1080i or 1080p output. any opinions would be greatly appreaciated
I have the Oppo 981 HD and overall am very pleased with it. One difference between it and the cheaper Oppo's is it's ability to play SACD's and DVD-Audio.
The only problem I have had is that it has problems playing DVD's created by an older DVD recorder I have which were created on -R's and -RW's. What happens is that the picture stutters and you have to hit pause and sometimes rewind a bit to get rid of it. I would say this is very annoying and others have had the same issues as reported in the Oppo owner's thread. Strangely, I have a bunch of backup's I created with Shrink on my computer and are -R's and they do not exhibit this problem.
post #10208 of 14227
has anyone noticed the green blob appearing on the 2000's?
post #10209 of 14227
I did (60A2000). But it only happened on one brief occasion. I simply turned the set off and then back on. Voila! Haven't had the problem before or since.
post #10210 of 14227
Weird - same thing happened to me earlier this year. Blobs were there for about an hour (and I was getting very worried) then they disappeared and I haven't seen them since.
post #10211 of 14227
Why does the sharpness / clarity vary in different picture modes on my KDS60A2000 Sony SXRD? I've read about alot of professionals & average users who have theirs in "Custom" mode (along with various other tweaks), but my "Custom" picture mode looks like I'm watching TV with water in my eyes. In "Vivid" mode, the picture is razor sharp, in "Standard" mode, the picture is less sharp, and in "Custom" mode, it's down-right blurry. Is this normal? Is there a way to correct the softness in the "Custom" mode? Is something wrong with my set? Thanks for your help!
post #10212 of 14227
You might come to a different conclusion if you were to look at test patterns from a signal generator and see what Vivid does to a signal. Perhaps you prefer artificial enhancement of edges and other artificial enhancements built into Vivid.
post #10213 of 14227
You can go into the advanced settings and max out detail enhancer and edge enhancer. That should make it look "sharp" like Vivid. Maybe max out live color if you want the garish colors to go with it.
I think Vivid and Standard basically have some of the advanced settings you can't get to in those modes preset in various ways. They could be more extreme than what you can get in Custom-Advanced, but I'm not sure. Max is pretty extreme.
post #10214 of 14227
vivid maxes out contrast and detail enhancer
not a very natural look
OP should try custum - advanced - detail enhancer medium for a few days then low then off
if you have a good source everything in advanced can and should be turned off
post #10215 of 14227
The best way to do it is with a component video connection. If you go the ATI store you can get the DVI to component adapter that works for your card.
post #10216 of 14227
You will notice some lack of detail if you are watching a DVD or stand cable. I have my sharpness at around 46, with detail enhancer on. I dont use any of the advanced settings except for detail enchance, and placing that on low gives me just a very small amount of enhancement.
Try and stay away from the other advanced settings, they can really kill the picture.
post #10217 of 14227
Thanks for the tip.
Anything else all mighty one?
post #10218 of 14227
reset ur resolution to something the tv will recognize. i use power strip and i have it set to 16:9 and custom resolution at 1820 *1024 or something similar to that. that should fill up screen.
you can also just get the resolution at 13XX * 768 (i think thats one of the standard options) and just change the size of the screen on the tv using the wide button until it fills the screen.
post #10219 of 14227
KDS-50A2000 (My unit was bought in August 2006 and the bulb has 1550 hours on it.)
Hope some one can help me with is one.
While watching dvd's, or TV I see bands of green and red moving from the bottom to the top of the screen. Each band is about 6" high and runs horizontally across the screen. It is visible for about 45 seconds as it travels up the screen and upon reaching the top, starts over again from the bottom.
I am running component from my Comcast/Motorola HDTV STB to an Onkyo TX-SR805 receiver which is outputting it as 720p over HDMI. I use a PS3 60gb for Blu-ray DVD playback also running thru the SR805.
Thanks for any feedback.
post #10220 of 14227
So all the sources come thru the same input and all exhibit the same problem?
To isolate the problem, try connecting your STB and PS3 directly to the A2000 on different inputs. Do they still exhibit the problem? If so the problem is probably with the set. If not, does either exhibit the problem? If not, the Onkyo is probably introducing it.
post #10221 of 14227
Yes, I am feeding everything thru the ONkyo TX-SR805 via HDMI to the A2000.
Ok will do. I should be able to isolate this issue. I guess this issue is isolated to my setup so something must be "set" wrong.
post #10222 of 14227
This sure sounds like a "ground loop" problem. First step is to make sure the power for everything is on the same ground (for example, is some equipment connected to a surge suppressor or something).
post #10223 of 14227
Hello all new to this forum. Had my set since late Dec. 06. I've got 2 problems with it I wanted to throw out there as they don't fit the usual problems I've read extensively about. First problem is a dark(stain) transparent blob in middle bottom of set(right above SONY emblem). It is most noticelably on bright white backgrounds. I have it on all input sources. It's not green and it is there at all times though you only notice it on white backgrounds. The second problem is my HDMI 6 port. HDMI 6 has a picture that looks washed(color not as vivid) out compared to HDMI 7 or Com Video using same input source. I had a servicer come out in March and long story short he said the thought the dark discoloration was screen problem and the screen would need replaced. He said I could get a second opinion. He brought a HDMI board but complained it was a 4hr job and seemed like it was a real pain to change so I bascially got a uncomfortable feeling having him do it. I finally got around to calling a different provider last week and described the problems. They beleive the dark stain is a OB and not a screen. They've ordered a OB and a HDMI board and when parts come in are going to pick it up and replace in there shop. I have a more comfortable feeling with this service provider. Wanted to get your thoughts. Thanks and let me add I do love this set if I could get these 2 pesty issues resolved.
post #10224 of 14227
I have noticed similar problem. Setup is SA HD cable box and LG 3510 feeds going into HK 635 receiver via component. HK component output to 60A2000. When using the external tuner on the 3510, we noticed a thin horizontal line traveling from bottom to top when we tuned into a preset channel with no signal (i.e. dark screen). We then noticed it during dark scenes on DVD playback and cable viewing. The line noise is not evident when watching OTA signals so I have assumed that the noise is coming from the receiver connection. I guess it could be from the input jacks on the Sony but have not checked that out yet. Maybe I should as the line noise was not visible on the Samsung 4226 that was originally connected in the setup. TV is on a separate surge protector as it is approx 20 ft from the A/V equipment.
Brett
post #10225 of 14227
Note my earlier post! To avoid ground loops, everything must be plugged in to the same ground point (among things, as there are also other sources of ground loops).
post #10226 of 14227
Originally Posted by whitesanjuro View Post
I've noticed an issue with my KDS-50A2000 that has taken me a while to track down. I first noticed it a few months ago when watching a borrowed copy of Babel on Blu-ray via my Playstation3 (pre-1.8x firmware). Really dark/black scenes (e.g. chapter 2 in when Amelia is walking down the dark hallway) looked almost blue, as if my brightness was set too high. I dismissed it during the viewing (although it was very distracting) and didn't think about it for a while.
More recently, I upgraded from a 360/add-on to a Toshiba HD-A20 and purchased Babel on HD DVD, hoping the AVC/MPEG-4 encode would look better than the MPEG-2 on the Blu-ray version, but to my surprise it did not. I tried adjusting the black level on the A20, as well as connecting directly to the TV w/ both component and HDMI (I normally use 1080i/HDMI through my Yamaha HTR-6090 receiver), and adjusting the black corrector and gamma settings on the A2000. During this testing, I also started noticing subtler, but similar black/blue issues on titles such as V for Vendetta and Lost in Translation. The PLUGE on DVE looks totally normal.
I saw the same problems on my 360/add-on over component when connecting directly to the TV and through the receiver via 1080i component (the receiver can do an A/D conversion to take 1080i component and pass it through the HDMI output, so I wanted to eliminate that possibility).
Next I started testing on my PC w/ the 360 add-on drive and Cyberlink PowerDVD. I have a 23" 1920x1200 LCD that takes both component, VGA, and DVI inputs and I tested a variety of scenarios: PC via DVI, 360 via VGA, and 360 via component. All of the these tests revealed lots of detail that I had never seen before and there were no weird blue/black problems at all.
TL; DR -> The problem appears to be related to my A2000, as the issue manifests itself on both the A20 and the 360, regardless of analog/digital connection and whether or not the receiver is in the mix. Similar tests on a different display reveal no problems with the sources.
I have no idea how to proceed, but I would like to test the Blu-ray version of Babel again, now that the 1.8x firmware has dropped and see if the issue still exists. Turning down the brightness removes the blue, but also masks non-trivial amounts of detail (treating the symptom, not the problem). Any suggestions would be very appreciated.
I definitely had this problem myself. In fact, I noticed it early on after my purchase. I would notice it mostly when watching widescreen 2.35:1 material that have the black bands above and below the picture. The solution for me was a complete and thorough professional ISF calibration. Afterward, the blue/black problem disappeared. But what I did as an interim measure was to keep the Brightness in the 50 to 60 range, and to lower the Blue bias level in the White Balance section. Additionally, I swapped out my HDMI cable (had a low-cost generic and upgraded to a Monster 800 HDMI with stunning results). My guess is, the limited bandwidth of the generic may not have been conducive to 1080p. (Yes, there IS a difference between cables; no two are guaranteed to be alike. And though obviously you don't have to buy Monster or any ultra-expensive brands to get the job done, I don't want to hear any crap from anyone coming down on me and insisting that a $7 HDMI cable--which I originally had--is the same as a more costlier one that likely addresses bandwidth and shielding issues, etc., cuz I've seen and heard the difference with my own eyes and ears.) Anyhoo, those steps kept things blacker when appropriate. But the ISF calibration took it all one step further, and my Blacks now are almost ink-like, quite a feat for LCD/SXRD. Hope it helps.
post #10227 of 14227
I have read that the 2020 version and 2000 version are the same, Is that True?
i was going to pickup a 2020 60" version, but found the 2000 one for cheaper. If they are the same i would just go with the cheaper one then.
Thanks in advance for replies
post #10228 of 14227
Dan,
I did the same. I bought an open box 2000 and saved $800. I used the savings and bought a 5-yr extended warranty since this was the floor model. The sales rep thought that the response time on the 2000 was slower but checking on the Sony website, the 2020 and 2000 have the same specs. It seems the concensus here is that they are the same but with different cabinets. Do your research as concensus beliefs are sometimes wrong.
Brett
post #10229 of 14227
I was wondering if people thought the A3000 was worth waiting for or would I be best served to purchase the A2000 right now for a great price.
The A3000 will be more expensive, but I'm hearing the 120hz motionflow might be worth it if I'm playing Xbox 360 and watching sports as my primary uses.
anyone know if the A3000 will be worth the extra grand for that 120 hz functionality?
post #10230 of 14227
Thanks for the tip. I made sure everything ran thru the same surge. The issue seems to have cleared when I went back to HDMI from the Comcast STB vs Component whic I was using in order to get 720p via the SR805. I figured that the SR805 would upconvert the image better than the Comcast 3412 STB.
I now let the Comcast upconvert to 1080i and pass through the Onkyo Sr805 as HDMI 1080i. I'm not sure what setting I had incorrect but the HDMI cleared it up.
  Back to Forum: Rear Projection Units
