Originally Posted by joerod
Simple. Got it! You have to set the Ruby DVI setting to AUTO. Now I also learned that you can't use DVI input 1 then skip over to 4.
Interesting. I use #2 for my Toshiba (HD DVD) and #3 for my Samsung (Blu-ray) player. 1 and 4 are not used. :rolleyes:
It took me awhile to type the following response and submit it. Didn't see the above until I was ready to post. :o
funlvr1965, make sure that your Ruby is set up for (AUTO) DVI. Pressing the Menu-->Setup-->DVI Signal Sel. (AUTO).
funlvr1965 & joerod, It can be tricky to get the lumagen to put out a smooth 48Hz film cadence, but it can be done and it looks fantastic.
The following is a few of my own basic configuration settings to get a great picture from a film sourced HD DVD using the Lumagen HDQ, Toshiba A1 and the Ruby projector.
Note: USE AT YOUR OWN RISK!
These are my notes for settings on my equipment.
YMMV
(It would be helpful to me if you would point out any errors.;))
Turn on Ruby
Turn ON the Lumagen HDQ
Press the “Input #†of the connected Toshiba.
Reset Lumagen to factory defaults (Menu-->0999).
(To Configure the Lumagen HDQ for Toshiba A1 input, playing film sourced HD DVD’s and outputting to a Sony Ruby and using the Ruby’s DVI 48Hz “film Cadence†capability. This configuration avoids clipping of BTB/WTW, as 4:2:2 Color Space is available from the Toshiba A1, when asked for by this Lumagen configuration.)
Lumagen HDQ 1080i/60 deinterlaced to 1080P/48 - (Scaling OFF - Pass-thru mode).
(This is NOT a Constant Height Configuration.)
INPUT CONFIGURATION
MENU-->TYPE-->(select) HDMI 4:2:2 COMPONENT-->OK-->Exit the Menu.
Menu-->CONFIG-->DVI-->EDID-->USER-->OK-->YCbCr 4:2:2-->OK-->Exit the Menu.
MENU-->CONFIG-->ADJ-->SIZE-->SCALE-->(select) PASS-->OK-->Exit the Menu.
Menu-->CONFIG-->ADJ-->SIZE-->TOPL-->Adjust TL: -6, -11 / Default 0, 0 -->OK-->ALL ASPECTS-->OK-->Exit the Menu.
Menu-->CONFIG-->CONTRL-->GENLCK-->(select) ON-->OK-->Exit the Menu.
OUTPUT CONFIGURATION
MENU-->(select) Out-->RES-->VRES-->ENTER VRES: (enter) 1080-->OK-->(select) Progressive-->OK-->(Select Timing Option) Mode B-->OK-->Exit the Menu.
Menu-->(select) OUT-->RES-->VRATE-->ENTER VRATE: 48/Current: 59:94-->OK-->(select) 47.95-->OK-->Exit the Menu.
TO VERIFY CORRECT LUMAGEN CONFIGURATION SETTINGS, (when both the Toshiba A1 and Ruby are on):
With the Menu off, “OK†pressed once, will show the following values:
“IN PASS 1080i AUTOâ€
“OK†pressed twice:
“OUT: 1080P 47.95â€
“OK†pressed Three times:
“ANA OUT: RGBH-V-â€
“OK†pressed Four times:
“GENLOCK: LOCKEDâ€
“OK†pressed Five times:
“SIDE BAR PAN OFFâ€
To Calibrate the Ruby’s Brightness and Contrast to THIS configuration:
MENU-->(select) MISC-->TPAT-->PATS-->OK-->OK--> (> > > - to the CONTRAST test pattern)-->(Exit to turn off pattern)
From the Ruby’s remote:
Menu-->Picture-->Adjust Picture-->Contrast 84 / Brightness 46.
Paul
