Originally Posted by tim86
Thanks for the information. Since I'm getting the 50', would the settings reproduce the same picture as it would on the 60'?
Also I would sugest you compare your settings to these. There AGZELA's settings after an ISF calibration.
http://www.avsforum.com/avs-vb/showt...68#post8150268
The settings are almost certainly screen-size independent.
After giving AGZELA's settings a try, my opinion is that their worth must depend more than trivially on the service menu setting changes by AGZELA's ISF calibrator.
However, I did decide to make a few changes, partly as a result of trying AGZELA's settings:
1. Changed the Color Matrix to custom, using the default color mappings. I hadn't noticed the "Color Matrix" before. I'm pretty sure the RxXBR1s don't have that setting. [Note: It's not on the Picture settings page, but rather on the final settings page--the same one where the "Power Saving Mode" is located.]
2. Changed the Cinemotion setting to Auto. On the RxXBR1's, this setting is part of the Picture settings page. On the A2000, it's on the same settings page as the "Power Saving Mode" setting.
3. Changed the DRC Palette to (86, 26.) This differs from AGZELA's settings.
4. Changed the Color Temp to Warm1.
After further tweaking, I've made one additional change: I changed the picture (contrast) setting to 62 from 55.
I left all my other settings alone. I've edited my settings post to reflect these changes.
It may not be from the sharpness setting (decent chance it could also be from having Edge Enhancement or the Detail Enhancer setting set to anything other than Off), but the white edges on either side of the black gridlines that are over the gray background shouldn't be there.
), this is why for tests such as this I'd only really consider a test pattern from a 0dedicated HD pattern generator (or at least an HTPC) valid.
