craigsub - When is the shootout scheduled for?
post #31 of 919
7/24/06 at 6:34pm
Originally Posted by kramskoi
my questions for this sub are:
1. high pass filter...will one be used, and if so where and what order 2. power compression (@ 1.6kW), i thought i remembered reading on the SS website that they were 500 w/rms, albeit conservatively rated. the lower you tune this thing, the higher the distortion/excursion will be in 20-30 Hz area...now throw power compression into the matter...hmmm...i wonder...it's going to be interesting seeing the results of the tests...I would prefer to see this sub tested against a dual-sealed application (hey, we can start the ported vs. sealed wars again :D )...call it the proof in the pudding, as the results would be viewable by all. ;) |
Originally Posted by soho54
Exocer - What size port are you using in your sims? Just wandering.
Originally Posted by ransac
Are you trying to make a DIY that would make a practical commercial offering (size, weight, cost)?
Originally Posted by sherv
dual RP-L15 D2's in an 8.5cu volume enclosure, with a nice 10" pipe or dual 6" pipes, slap a Fs=15hz, and you will have something to cheer about that will make any Ultra/2 dual EP600s dual HO turbos (pick your poison, etc) look like child's play.
Originally Posted by craigsub
Ed .... We had a Denali here, and it was underwhelming in regards to sound quality. Several afficionados of the Tumult blamed the amp Kyle had at the time ... Does Kyle still make the Everest ?
| Here is the email I received today from Mike at splintersound... |
| ...Indeed, the 5.8 cu ft net volume spec is an EBS (Extended Bass Shelf) style enclosure. I arrived upon the number through computer simulation since I myself have not built an enclosure that large - however, I have read of other projects aiming for the low lows and using a 15" driver very similar to our RL-p, and they used a large enclosure with great success. So you could say that this recommendation is both calculated as well as based on anecdotal evidence. |
Originally Posted by Ed Mullen
(having a Homer moment here.........)
Outperforming nearly any OEM product is child's play. That's not the tough part here guys. The real magic trick is determining how far an OEM can push the size/weight/shipping envelope and still retain a viable customer base. Take the Acoustic Visions Everest for example. A DIY-OEM bridge offering if I ever saw one. Dual 15" Tumult, quad 18" PR, 10 ft3 enclosure, 410 pounds, beautiful woodwork, attractive design cues, relatively small footprint, no compromises on performance, and a steal for $2,500 ($3500 with suitable amp). And yet did the market embrace this well-conceived and executed subwoofer? Dual EP600s cost about the same amount of money....and would get stomped by an Everest in any objective performance contest. And how many EP600s is Axiom selling.......? |
| Not surprising given that Kyle Richardson is a marketing lightweight compared to Tom & Tom or Ian |
| Good points on the commercial viability of these huge subs ... one question we hope to answer ... How much does 20 cubic feet of subs enhance the theater experience ... |
Originally Posted by Exocer
You bring up a good point about distortion in the 20-30hz range...but let me play the Devil's Advocate and ask you this: With 800watts to each driver, you're getting close to xmax but never exceeding it really until the low teens according to Unibox. Would this distortion be realistically audible? One can assume distortion in a sealed allignment would be exponentially higher due to Xmax demands in the lower frequencies mentioned. :D
| SoundSpliner is a car audio company first and foremost, large and low ported boxes are out of their comfort zone. I'm not knocking them, just throwing that out there. I would rather see one of the current DIY home audio flavors of the month in your shootout, but that is just me. I would love to see how a monster sub compares, and I'm sure I'm not the only one. It would be like leaving out Velo or SVS. |
| As i stated, the lower you try and tune this box, the weaker it becomes in the audible bass range...and this is the meaty part of the pie as far as HT slam is concerned...but that's the compromise...get low and give a little high...always give and take in sub design. It's what is more important to the end user that counts. |
| Where do you draw the line on the size/weight/shipping issue? At what point does this merely become an academic exercise in the laws of physics and cease to become a legitimate comparison between subwoofers that consumers will actually consider purchasing and using in their own homes? |
Originally Posted by steve nn
A very legitimate thought as always Ed, but then how many users do we see doubling up on what they have? Although it's a nitch market per say, would a LLT sono really be that extreme considering all the dual and triplets out there? Shipping such a unit is a breeze and well within the constraints that would discourage such a prospect I assure you.
Originally Posted by Craig
It would be a real treat to have you here for the GP session, too.
| when the voice coil heats up, to whatever degree, the Q (peak) of the box will rise in proportion...the higher the temperature, the bigger the peak, and the alignment is becoming unstable...i.e. the frequency response (sound signature) is changing...the resistance is rising and the amplifier chokes. You also have the notorious BL drop as the excursion increases, this introduces more distortion to the system as you approach and exceed xmax. |
Originally Posted by HOTDIGITY
Okay........for us dummies.......what's LLT?
| Okay........for us dummies.......what's LLT? |
