AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Olive Opus: First Impressions
Olive Opus: First Impressions - Page 6
post #151 of 1135
chuckle, nope silver too boot. alas.
post #152 of 1135
Got an email from Olive today announcing their new web site, updated user manual (yeah!), and renaming of their products (all are variations of the 'Opus' name now). They also mentioned that the Sonata had problems that prevented its release, but they are working on a replacement of some sort.
Olive Web Site
post #153 of 1135
called again, and another 5 weeks before it will be ready....
post #154 of 1135
I noticed on the web site that the Opus No5 has been totally redesigned...maybe the original Opus is out of production, and that is why they've been unavailable?
post #155 of 1135
Guys. I need some help. My computer crashed and back up failed so I lost all my back up rips of my CD collection. I still have everything on my Opus.
Can I use the USB port on the Opus to copy everything on the Opus and then import it into iTunes? All the files on my Opus are in Aiff so there should be no compatibility problem.
Thanks for any reaction.
post #156 of 1135
Jack, if your Opus is connected to your home network, you should be able to open the files (on the Opus) using iTunes. I was just messing around with this last night. Mine are stored in FLAC, though, so iTunes won't play them. I have not tried it, but you should be able to do a direct transfer from the Opus to iTunes. That should save you a step. Let us know if it works!
post #157 of 1135
Hmm. Sounds good. First I have to set up properly file sharing again. That was a bit of a hassle the last time around and now that I have completely reinstalled the operating system I will have to do it again. The hassle is that i have a few computers on the LAN and IIRC you have to set one computer to "take the lead" otherwise if you log computers on and off the LAN the file sharing gets messed up.
So once I do that and my desktop sees the Olive I should be able to open iTunes and see the Opus and import all the files just like that? Nice if it works. Maybe I'll have time to fiddle with it tonight when I get back home.
thanks.
post #158 of 1135
Well, I was looking at this some more, and it may not be possible to copy directly to iTunes. The Opus is considered a 'shared' device, and iTunes cannot copy from shared devices (just play). So, you will probably need to go with the USB connection to an external hard disk, and then import from that.
post #159 of 1135
Olive tech support said I should be able to do it by attaching a USB drive to the Olive and copying over. Then I can plug that into my desktop and import into iTunes.
I'll keep you posted so if it happens to someone else there will be a record of how to deal with it.
post #160 of 1135
Geez! Turns out the hard drive has to be formatted with FAT32 to work with the Opus. VISTA or XP, however, will not allow one to format a disc larger than about 30GB with FAT32. So now what do I do? This is a big fat pain!
Also Olive seems to have indicated that it will not be possible to import the songs into iTUNES even if I manage to pull them onto an external hard drive. I don't see how that could be. Once they are on a hard drive attached to my desk top I am pretty sure that I can import them.
post #161 of 1135
I bought a Maxtor external 200GB drive shortly after getting my Musica, and I did not have to format it at all (came preformatted). Just plugged it into the Musica's USB port and it worked fine.
post #162 of 1135
Hmm. Maybe I can find a pre-formatted one too. Thanks for the tip. Probably these guys at Best Buy and Compu USA won't have a clue about the formatting. Maybe it will say somewhere in the fine print on the box.
post #163 of 1135
OK FYI: I picked up a 500GB Maxtor USB drive but it was preformatted with NTFS. I found a great site that has a little program to format a drive with FAT32 and step by step instructions.
http://www.ridgecrop.demon.co.uk/ind...at32format.htm
Basically you have to delete the partition on your new drive. Then from Windows Disc Manager you assign a drive letter but do not format the drive. Once you do that, you open the little program from a dos prompt and tell it to format your disc. Boom!
As for the Opus, you just turn it on, and then plug in the USB drive which will show up on the main menu. Then go to your albums view, mark all of them, add them to a list and choose the USB drive as the list to add them to just like as if you were making a playlist. I'm in the process of copying my entire library to the USB drive now.
I'll let you know later my experience about reading the library into iTunes. I REALLY hope it works!
post #164 of 1135
My next suggestion would be to permanently hook up an external drive to your pc to do automatic backups on a regular basis!
post #165 of 1135
Yup. The sad fact is that I have about 5 external drives connected to my pc but the backup strategy was "less than optimal."
post #166 of 1135
Here's another question. Have you noticed that there is no mention any more on the Olive web site about streaming music to other rooms? They used to sell a device that you could connect to a system in another room and stream from the Olive. If it's on the web site I couldn't find it. So was that a bust? They couldn't make it work and gave up?
Update: Olive confirmed to me that they are not currently marketing the hardware that allows you to stream from your Olive to other rooms (I forget now but I think it was called Sonata). They said they are upgrading it and expect the new version to be available in early 2008. In the meantime they said you can use third party devices like Roku's to do streaming.
post #167 of 1135
Good grief! The Opus has been copying files to my backup drive for 12 hours!!!! I have maybe 250GBs of material but... still. Well I could see this morning that the copy indicator is moving and it's going from song to song. Just hard to believe it's so slow.
post #168 of 1135
OK. So just to let you know: It can be done. I copied my library from the Opus to a USB drive. Then I plugged the USB drive into my computer and imported the library into iTunes. No problems just a lot of time consumed.
post #169 of 1135
Thanks for reporting back, Jack. Good to know it can be done. Hopefully, iTunes would be able to convert my FLAC files into something it can play...if so, I just might have to pick up an iPod one of these days.
post #170 of 1135
Nope iTunes cannot deal with FLAC. It's a real bummer. I ripped everything in aiff and left then in that format to load both to my Opus and my iPod so to avoid additional conversions.
I guess I have a modest enough collection because it almost fits uncompressed on the new 160 GB iPod (just have to select several albums not to load) and of course easily fits on my Opus.
I couldn't live without an iPod. Use it in my car, working out, on planes......The new 160GB seems to have better DACs than the older ones. At least it sounds better to my ears.
post #171 of 1135
latest info is that they should be shipping me the opus 5 on november 12th. we shall see...
post #172 of 1135
It is my understanding that the Roku Soundbridge does not play flac compressed songs. I would love to stream music to other rooms but will have to wait for Sonata to be rereleased.
post #173 of 1135
I talked with one of their sales guys yesterday. Told me the No.5 won't be available until early December. I live just north of SF so will plan on checking it out (they are planning to have a demo room). I currently have an Imerge and anxious to see how this sounds.
marty
post #174 of 1135
So has anyone actually recived one of these yet? I won one (well the right to buy it at less than half price) using AMX's wishlist but they said it would take 2 to 3 weeks for it to be delived. Just wondering if it is actually worth keeping or should I just try to sell outright?
post #175 of 1135
If you want to sell an Opus No5 for half price, call me...I'll take it off your hands!
post #176 of 1135
Who knows I might sell it, but was wondering if anyone actually had one and what did they think of it. I have seen several up on ebay (they were saying they would not be able to deliver for 2-3 weeks (must have been wishlist winners also)) but would like to get some feedback on the device. . .
post #177 of 1135
I just read 6 pages of posts because I also won the right to by a Opus No 3 through Amex for half price. Amex already charged my credit card, so it better be on the way soon.
post #178 of 1135
apparently it has shipped and will arrive this week. unfortunately i leave for the holidays, and wont be able to use it until January. It has been nearly one YEAR since it was ordered.
we shall see if it was worth the wait.
post #179 of 1135
WOW a whole year! I might just have to hold on to it, of course I still have no idea when it will ship. . .
post #180 of 1135
I too bought one on the AMEX wishwist promotion. Has anyone been contacted by OPUS? I was told by AMEX that they would call everyone within 7 business days (it has been 9) and I haven't heard from them. I called them and was told to email them at care@olive.us. Tried that and the email was sent back to me as undeliverable. Not too impressed with their customer service so far.
