Another popular misconception is that HD is inherently grain free and that
film is inherently grainy.
Nope.
Originally Posted by
suprmallet
If there is grain in Miami Vice, it was added in post, because Miami Vice was shot on HD.
Nope.
HD is not noise free.
Noise in MIAMI VICE was from production HD cameras.
ChrisWiggles
Nonsense. Digital cameras have noise too. It's not film grain per se, but you can certainly characterize it as "grainy" noise. It's certainly there on many shots in collateral.
Good point.
Digital noise / compression artifacts can look like film grain.
COLLATERAL has some digital noise shots . . . more so in MIAMI VICE.
PLUS, in addition to the noise there is a temporal shift that caused motion artifacts in some shots in both films to really look like video.
Most of the time what manifests itself as "film grain" on a movie transfer
is compression artifacts growing around the grain. This can come from
a bad film print and/or poor IE bit starved compression.
trbarry
I predict that DOP's will start showing less "artistic intent" and start making more movies that compress and sell well on electronic media.
Spoken like a true computer person; you make "artistic intent" sound like a bad thing, Tom.
I certainly accept that any new medium, or component of any new medium,
wants to be acknowledged and accommodated . . . TO SOME DEGREE.
That said, the tail does not have the right to wag the dog.
As our good friend VC-1 compression guru "amirm" has said in the Industry Insiders Thread,
it is the job of the encoder to reproduce the source not to change the source.
If the encode isn't working you change and/or vary the encoder . . . you
don't change the source. . . . and you certainly don't accept the encoder changing the source.
trbarry
Hint: Electronic softening, strange lighting, and coloring can give the same looks of unreality but still compress much better than excess grain.
In a word; no.
All those effects [ I assume you are referring to HD origination ] can be as difficult if not MORE difficult to encode than film grain.
I don't think that's the point.
The point is that any reasonably competent film or video cameraman can make
a clean image that is "easy to compress" . . . . altho I do think the term "EASY to
compress" is a bit of an oxymoron. Ask our friend compressionist "Cjplay"
also in the Industry Insiders Thread.
The trick is to make an artistic image that works on film AND on digital . . .
and it seems that the better directors and DOP's are doing just that.
Circling back to my lead sentence; the misconception that HD is grain free and
film is grainy.
CAPN's TIP for TELLING FILM GRAIN FROM DIGITAL NOISE / COMPRESSION ARTIFACTS
-- film grain is of uniform size and position within a given frame. It does MOVE
between frames but it is still the same size and position.
-- digital noise / compression artifacts can be of varying size and positional
density with in a given frame.
-- digital noise / compression artifacts can tend to "cluster and grow" around
different areas in the frame . . . and the "growth" can be of different sizes.
CAVEAT; like all tips there are exceptions.
This is all changing pretty quickly.
I'm looking forward to seeing what Tony Scott and Paul Cameron are doing with
Genesis HD on DEJA VU and what David Fincher is doing with UNCOMPRESSED Viper HD on ZODIAC. The little I've seen looks very impressive
NOTE; not to suggest that Michael Mann and Dion Bebee are not terrific
filmmakers . . . . MIAMI VICE was simply not to my particular taste. . . and it WAS noisy here and there.
Respectfully submitted,
CAPTAIN CELLULOID; DGA: IGC, IATSE
Film Guy Using Digital To Make Film
