Hi, hopefully someone knows this information because CSW/Hi-Fi.com no longer has the info. I have [an mostly original
Movieworks 5.1 speaker system. I am seeking the frequency response and crossover frequencies for these speakers in order to calibrate the speakers using an SPL meter. I have a new HK AVR 2600 and don't quite trust the frequencies that the EZ Set EQ came up with. I had to adjust everything including the speaker distances manually. They are:
Movie Works 5.1 LF, RF
Center Stage Ctr
The Surround 5.1 LR, RR
BassCube 8 (pre 8S) This I bought separately to replace the passive sub that came with an Ensemble IV 5.1 system I had years ago.
The HK setup the speakers with the following crossovers. The Fronts 150Hz, the Center (Large but I changed it to 150Hz to match the fronts), the Surrounds 40Hz. From what I understand the sub is set at 100Hz by the receiver automatically but you can select the size of the driver which is 8in..
I called CSW and they could not find specific info for anything but the Center Stage speaker because they are all discontinued. What they told me was this:
Fronts 100Hz-20Khz
Center 58Hz-20Khz
Sub (BassCube 8S) 39Hz-200Hz
What's the real deal with these speakers? Thanks in advance.
