Just a heads up, maybe it's been covered...
But MF5 will convert *.m2t (ts file) to HD-DVD without the intermediate step of using Womble (or other utilities) to create a program stream file.
Just rename the filename extension of the m2t to *.mpg
When you click on the video file, the "INFO" button will become grayed out. The program will appear to freeze up but the hard drive activity led on your pc will churn for a couple of minutes or so as it scans the file headers. There's no progress indicator, but as soon as the "INFO" button returns from it's grayed out status, choose "OPEN."
MF5 will display a message that the file is not editable. "Do you want to create an editable file?" Choose yes, and MF5 will perform pre-processing to create an editable file. It takes a few minutes but no re-encoding is involved. You can thereafter go about creating your chapters, make edits and create HD-DVD folder ready for burning.
This procedure saved the day for me with an HDV file that wouldn't process the PCM audio correctly with Womble. MF5 processed the audio correctly when allowed to handle the conversion.
I would assume this works with MF6, but I have not yet upgraded to confirm.
