ok, problem solved, thus far...heheh.
if i close the disc tray using the "play" button on the remote, the DL DVD+R plays fine
if i use the open/close tray button on the remote, the disc is not recognized.
also, just because one of my discs worked doesn't means it will always work. i found that i still had to load a retail hd-dvd or dvd or dvd-r backup before loading my DL DVD+R. BUT now i think i've found a workaround, just by using the Play button to close the disc drawer. an odd fix and maybe a firmware 1.4 bug.
guess i'm just glad it works
if i use the open/close tray button on the remote, the disc is not recognized.also, just because one of my discs worked doesn't means it will always work. i found that i still had to load a retail hd-dvd or dvd or dvd-r backup before loading my DL DVD+R. BUT now i think i've found a workaround, just by using the Play button to close the disc drawer. an odd fix and maybe a firmware 1.4 bug.
. I do know I was able to make a short HDDVD clip and added music to it a couple of days ago. It was from my piano keyboard to a cd recorder. Then I took the cd and added it to the video. I can't get any of those "homemade" tunes to work now either. Maybe since I don't have the full version of Ulead, which could be causing my problems. It seems like when in Ulead and it says "Add Audio" that you should be able to just add songs from anywhere on your computer! Ulead is the only program that will see my HDV footage when I hook the camera up to the computer. Does MPEG2Repair see it also? Steep learning curve here
