Originally Posted by ThrottleAbuse
I have not made any disks since I got a new computer. My old one died so this is a new computer. As near as I can tell the settings are all the same as when I made mpeg2 disks. I did not add chapters. A2 shows not compatible disk.
I will try and and make a .ts file with tsMuxeR with the EVO. Maybe I will try and reinstall MF6 and the powerpack.
If you are using DVD+R disks then you need to set the "book type" in Nero to "physical disk" so when the burning starts Nero will state that it is a DVD+R instead of DVD ROM disk type. Not all burners allow the book type to be changed. In Nero it is in the choose recorder setting click on your burner and down on the left side is a tab to click for more settings. If you cannot change the book type then you need to use DVD-R disks for playback on the A2.
I would suggest you try an mpeg2 file that you know did work and see if you can make a disk that plays, then try the H264 file.
Mike T
Could anyone confirm this or do I just have a bug ?
