AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What to clean Westy LCD with?
post #1 of 5
Hey guys I have a westinghouse ltv 32w6 and I was wondering what I need to use to clean the screen off with? Let me know because I don't want to damage the screen in any way. Thanks and I appreciate all of the help!
post #2 of 5
dampen/moist towel or paper towel does the trick. Just don't use any alchol or amonia base reagent. It can eat off panel coating.
post #3 of 5
I use this product to clean my PDP TV & LCD monitor screen(s): Monster Cable TV Screen Cleaning Kit
post #4 of 5
Do not use wood (tissue, paper,...) Use the cloth for glasses, lenes,...
post #5 of 5
I would use a damp microfibre cloth. Don't use paper towels, anything paper based can scratch. You can find good microfibure cloth's at any car store since they are the cloth of choice for applying and removing wax from car clear coat without scratching
This thread is locked
