Originally Posted by
colin6969
Across the board, I use:
Color temp: normal
ADC: Off
Sharpness: 0 (I've tested this a lot....I've yet to see why you'd take it out of 0)
Colors: factory set....considering experimenting with red levels over HDMI
Moto Moxi 9133i HDTV via HDMI:
Brightness = -1
Picture = 10
I've found white levels to be basically your call because you can't crush whites without the service menu....i just experimented for awhile before deciding that 10 wasn't too bright, yet increased the 'pop' a bit while maintaining contrast...and it helped the wife factor too..
Xbox 360 via VGA:
Games:
Brightess = -10
Picture = 10
DVDs:
Brightess = -1
Picture = 10
Again, 10 was chosen subjectively. Anything higher makes my eyeballs start on fire anyway.
Sounds similar to my settings for HD. Some programs look a bit soft to me, so I put sharpness +1, others at 0. Still haven't figured out a perfect overall setting for picture, brighteness and input level. Different content requires individual tweaking. In general, input level + 8-12, picture + 6-14, brightness +0-6. I also use black extension +1 on some material.
Of course, on SD material, all bets are off, and settings can change pretty wildly!
I don't remember what i use, I'll check, but I've certainly been able to optomize the image so that it resembles the old CRT more than whan I first got the 9UK, when SD looked terrible. I'll post SD settings later.
Anyone else want to post their post-break-in settings?
