I'm looking for some advice on an LCD panel for my MBR. Basic criteria I'm looking for are as follows:
Screen Size: 32 to 40 inch
Built-In Tuner: Doesn't matter since I plan to use HD DVR from cable company
Cable Card slot: Would be nice but not required
Speakers: Must have because I don't plan on using an audio system with the unit
Inputs: Needs to have HDMI plus other standard ones. I plan on hooking up a HD DVR and most likely a DVD playaer
1080p: Not required but would be nice if price were right
Other particulars: This unit will be about 10 ft from the end of the bed flush mounted on the wall. Not sure what will be the right screen size from that distance. Hoping a 32 will cut it but I'm not so sure!
Price range: Would really like to keep the TV cost at 1500 or less but can go more if it makes sense to do so.
Any help that all of you smart guys and gals can give would be much appreciated.
Thanx
Barry
Thanx
Barry
