Originally Posted by derek
Hey Clarence I'm ready to order a 5'x10' sheet for my Zenith Pro 900x CRT but the important question is: How well do kids fingerprints wipe off?!?!?
Two other questions:
- Has anyone tried to cut the material? My size will be 52x92 (106 diagonal) and would like to lop off a bit on the sides at least.
- Anyone attempt to paint the surface (ie masking purposes, hide mounting screws etc?)
Be warned that these 5x10 sheets (at least mine) was 5' 1" x 10' 1 1/2"... you'll have two cuts to make on this if you drop your size down that much.
For cutting... I did the put some tape (I used painters tape, the blue stuff) down and marked my cut line on top of that. The sheet they gave me at the Home Depot said to score repeatedly with a utility knife on your line until you cut though. I did that for about 18" worth of my one cut, and gave up as it was going to be a long process. I didn't want to haul this thing back upstairs and setup the table saw and my circular saw blade isn't very sharp so I was afraid to use it as well. What I ended up doing was scoring the surface once or twice on my line just to break the tape and the very top surface of the laminate. After that I *did* use my tin snips. I cut in very small increments (maybe 1/4" of an inch at a "snip") and came out with a beautiful cut edge with no problems. I noticed if I tried to take large cuts (1/2" or more at one "snip") that the board wanted to delaminate (I tested this on what is now my left over piece before I cut on my actual line so I could test my procedure). So, trick was to "roll" up the cut piece as I made my way slowly across the cut. I scored the cut line only to help keep chips and such from forming... don't know if it really helped, but figured it couldn't hurt. It also worked somewhat as guide for the Tin Snips to follow as my snip blades fell right into the scored line nicely. In the end it was much quicker than making multiple scores with a utility knife.
I have my molding cut to size but haven't wrapped it in velvet yet. I used the small metal 1/8" mirror mounting brackets (from a side view they resemble an "S" with a 1/8" step) to hold up the laminate sheet. Seems to work really nice. I'll cover my baseboard (primed pine 3" baseboard) with my velvet from JoAnn's and I think I'm going to build small french cleats to attach to the boarder frame and hang that way.
