Originally Posted by Overtone
Good find, it is a better size indeed
Here is the room treatments thread. Now... my speakers are kind wobbly on the carpet as well. So maybe something rigid is what I need, so long as it works the best on sound quality and vibration isolation. Did you try listening to the subdudes to see how you liked the effect?
http://www.avsforum.com/avs-vb/showthread.php?t=901434
Nope, did not listen.
