AVS › AVS Forum › Audio › Speakers › Focal - JM Lab Owner's Thread
Focal - JM Lab Owner's Thread - Page 151
post #4501 of 5777
I found the reference to the center stand here
ww.signals.uk.com/.../focal%20Price%20list%20sep%202009.pdf
note there is a w missing
also I have a possible pic but I cant post it yet
post #4502 of 5777
Is there a sound quality difference between using L/R preamp-out connections vs. LFE-out connection?
I currently use LFE-out, but want to use L/R preamp-out to activate the s/w instead. My preamp (Anthem AVM50v) processes my phono-out through internal ADC (to use Anthem Room Correction), and I want to keep the analog signal as pristine as possible. Only way to do this seems to be to bypass the ADC, which in turn means no ARC or s/w LFE out, so leaves me with no choice but to wire s/w directly using L/R preamp-outs.
I would normally try this out before asking, but I do not have long enough cables to experiment. Before I plop down $, I thought I'd ask you experts
post #4503 of 5777
I,m Hong Kong guy, maybe i don`t have good english to explain, but i hope people can understand my meaning!
Actually, i was gone AV second hand shop to check JmLab 1007BE, it have good price!
When i looking 1007Be is artwork craft, but i dont have good AV/Hi-fi equipment to cooperate.
My AV system:
AMP: Denon 3808 (A)
Font Speaker: Want buy JmLab 1007be
Centre Speaker: Piega P4C MKII
Surround Speaker: mirage omni 150
Subwoofer: Chario SW2
I hope JmLab user can give any suggest to advantage or disadvantage!
Seller said, it have 99% condition, and Price Sell US$2060, i dont know it is have good value to deal.
Thank You Very Much!
post #4504 of 5777
Trying to find out which line of Focal speakers would be a good match for my Arcam AVR 600? Looking to do a 5.1 system. Want something that is great with both movies and music. What should I take a look at?
post #4505 of 5777
FWIW, I have an Arcam AVR350 pushing a Profile 918/cc908 front stage. I ended up adding an Emotiva 3-ch power amp to the mix to take some strain off the AVR. With the 600 having more power than the 350, this might be a good match. If you were to get into the Electra line, you would probably need some external amps to at least drive the fronts....
Should be just fine for anything in the Chorus line.
post #4506 of 5777
Here is a review of the Electra 1028Be and its buddies....
http://www.hometheater.com/content/f...speaker-system
post #4507 of 5777
I would say that is a very good review overall. I am still anxious to get my chorus 705's for surrounds. But I still love my 1027's .
post #4508 of 5777
I found it to be a little 'movie heavy'
There wasn't really much about how they performed with music.
I read another review that mentioned there was an improvement over the sound of the 1027's, but I have heard neither so I have no input on this one...
post #4509 of 5777
I am not sure about the price but from my experience of the lower level Focals (816W & 826W) with a Denon 4308 I think you will need more power to drive them properly. After a number of power amps I have settled on a 2nd hand Rotel 968 (?) 5 channel power amp in-front of the Denon to drive my 5.1 system.
You should be able to get a decent 2, 3 or 5 channel power amp for not a huge amount, just do research as to what will work best and be prepared to swap it out for another altenative later like I did.
post #4510 of 5777
Unfortunately it is a Home Theater magazine so it would make sense that they would lean to that side. I would also say that there is more then likely an improvement over the 1027's. I had the 927's which have the same size drivers as the 1027's yet the 1027's are better in just about every way. The 1028's have the same size mid and bass driver and I think the tweeter is a bit bigger. The 1027 had a 1 in tweeter and the 1028 has a 1 1/4" tweeter. Plus it is a generation ahead and I am sure they worked on the crossovers as well. So I would guess that the 1028's would sound "better".
post #4511 of 5777
To the moderators,
Please remove this post as it is likely against Forum policies. Thank You.
post #4512 of 5777
I recently purchased a set of Focal Speakers to be driven with marantz sr7005.
I heard they work well together.
My question is, what kind of stand should i look for or diy, to use with center CC800V? I don't think Focal have one for center.
There are no holes on the bottom or back of the speaker, so how to make it stable?
Thanx..
post #4513 of 5777
Thank you for your information, anyway, i was got 1007Be, that all performance for very prefect! It provide Hi-end and enough Bass!
And Denon 3808 was easy drive it!
post #4514 of 5777
Can I keep the LFE and low-level RCA inputs plugged in at the same time?
I would use LFE for home theater, and low-level RCA for pure audio. My A/V processor does an ADC-DAC conversion for music and I want to keep my audio path free of the additional processing.
Leaves me with no choice but to connect the sub in both ways, and I want to make sure I don't blow the sub in home-theater mode (i.e., with juice coming to the sub from both the LFE and low-level RCA inputs)
post #4515 of 5777
Hi, having an issue running Audyssey with my 826w. I keep getting a phase warning but I have them wired correctly. According to Audyssey FAQ this may be because of the speaker manufacturer internal design. Anyone experience this with thier Focals?
From Audyssey
It's actually a Phase Warning and not an error. It can be triggered by how the speaker interacts with the room and also due to intentional design decisions made by the speaker maker, particularly when there are multiple drivers involved. It is there to have you check the wiring on the back of the speaker and the back of the amp. If it is correct on both ends, then simply hit Skip and proceed. It has no effect on the resulting room correction filters.
post #4516 of 5777
As per my PM, just swap the inputs (red/black to black/red) to the 826Ws and then rerun Audyssey - the problem went away for me during testing.
post #4517 of 5777
Im leaning towards a Focal Chorus 836v and 800 series 5.1 setup, mainly for HT and some music. HT 80% music 20%
Amp choices:
Pio Elite SC-37
Denon AVR-4311
Marantz SR7005
Any suggestion would be much appreciated.
post #4518 of 5777
I'm using the sr7005 with the 826w and think it sounds great. Recently switched from an Onkyo and it was as if a veil was lifted from my Focals in terms of clarity especially in direct or 2 channel stereo modes.
post #4519 of 5777
im thinking of getting the marantz av7005 instead of the anthem mrx500 now, hhhmmm
post #4520 of 5777
I just purchased a set of Focal Electra 1027s fronts. I was wondering where I can grab a Focal Electra cc1000s or CC1000BE center for a good price. My local dealer is asking for $2500 and $3200. I think it is a bit too expensive. I checked audiogon already and I can't find one. If anyone has one for sell, please pm me.
post #4521 of 5777
cmchen0, if you have the time (and patience) I'd just wait until one comes for sale. It took me a while to find my Focals through the used market. Couldn't be happier...
post #4522 of 5777
I have 816S's, what center will get me a close match since I don't want to pay or spend the time looking for the matching one?
post #4523 of 5777
Why not the CC 800 V?
post #4524 of 5777
They are going to be hard to find I think. I bought one in a premium finish and it was in the higher end of what you quoted. I think the retail when new was close to $2700. I got one of the very last ones direct from the company itself.
Well, what do you know, I guess this just popped uphttp://www.audiogon.com/cgi-bin/cls....-cc-electra-10(edit-sold)
Even if it does not match your finish, mine does not, I would jump on that. I just re-read and I think, now reading it you are saying that you have the 1027s series, not Be series right? If I am right then you need a "S" center. If that is true then I think the price that dealer quoted you is way off base. This site http://www.tweakshop.com/1000S.html
has it listed for much less. They seem to be pretty accurate on retail pricing.
post #4525 of 5777
It probably runs more than I want to spend. This is just for a bedroom setup. My budget is under $200. Also I have the older model 816S's not the 816V.
What about Boston Acoustics VRC since it is under $200 and free shipping from onecall.com?
post #4526 of 5777
Using a Marantz receiver SR7005 the max power output on stereo bi-amping is 220w per speaker... do you think 826V fits better for a setup over 836V, since this last one may be harder to manage for this amp.
Bear in mind, recommended power for 836V is up to 300w, while for 826V is up to 250w. So im guessing with an amp that limited on power output, I may not get the benefit on the 836's over the 826's.
What do you think about?
post #4527 of 5777
just bought a marantz av7005
post #4528 of 5777
I think that bi-amping a 7005 will not double the power to the speaker. In fact it may produce less power since you will be driving more of the amps.
Also think neither the 826 or 836 can be bi-amped.
post #4529 of 5777
This is just for a bedroom setup. My budget is under $200. Also I have the older model 816S's not the 816V's.
Anybody else have an opinion on this?
post #4530 of 5777
I didnt say "double". I said 220w, you may check receiver specs if you doubt.
So, are you suggesting I can not take benefit of the rest of power from the receiver and get the most of both amp and speakers when on stereo mode? what a waste of resources and money in that case...
  Back to Forum: Speakers
