AVS › AVS Forum › HDTV › HDTV Programming › Wheel Of Fortune and Jeopardy in HD
Wheel Of Fortune and Jeopardy in HD - Page 12
post #331 of 409
Interesting to note that here for Columbia SC, when we have a feed or record issue and don't air the shows in HD, we don't get any viewer complaints..
post #332 of 409
My wife and I watch Jeopardy often, and I almost always use WOLO because it's in HD. I remember seeing it come up in SD a couple of times, but I didn't worry too much about it because I know the mechanics of getting that thing on the air are more complicated than for network shows, and it's a daily show so it will probably be OK the next day anyway. If it were two days in a row I might drop a line to ask what's up.
If SCETV had messed up one of the "Great Performances at the Met" broadcasts, on the other hand...
post #333 of 409
I suspect the majority of complaints to stations regarding the lack of HD is for sports, and often from some AVS member. However if there is an outage, just let us know and I'm sure the forum members would be happy to flood the station with complaints.
post #334 of 409
Originally Posted by jtbell View Post
My wife and I watch Jeopardy often, and I almost always use WOLO because it's in HD.:
I knew you did.. And was quite surprised not to hear from ya. But you're right,
the logistics to do this is a pain, our MCO's would just as soon not bother with it.!
post #335 of 409
I tuned in tonight and, lo and behold, WJLA has them in HD. I have caught them on WMAR occasionally and was not overly impressed with the PQ. It just seemed a tad soft is the best way I can describe it. So imagine my surprise when I did an A/B comparison tonight and saw the marked improvement in PQ on WJLA between the two stations. That is watching WJLA on FiOS and WMAR OTA. I wasn't able to do a direct comparison since WMAR runs Jeopardy first and Wheel second and they run in the opposite order on WJLA, but still the improvement was there all the same.
I cut-and-pasted my quote of last night from the DC-Baltimore local thread FWIW. WJLA's operations and engineering director is a frequent contributor to our local forum so he will probably address this, but I was wondering if the PQ improvement could be a result of WJLA using the Pathfire distribution system. WMAR and WJLA are both ABC affiliates.
post #336 of 409
As far as I know, all stations are taking the linear HD satellite feeds for these two shows. Both of the shows are native 1080i, so cross-conversion is required by 720P stations. The HD satellite transmissions to the stations are at nearly 45Mbs which provides high quality.
Pathfire was sold about a month ago.
post #337 of 409
Hopefully for the better.. (We have 3 servers and 2 workstations)
post #338 of 409
Does a TV Station Have to be able to show HD News, to show wheel and Jeopardy in HD? Cuz in Houston the CBS station shows both Wheel and Jeopardy in HD, and They Have HD News. If that's true than It's going to BE a Long Time Before KDBC in El Paso can Show these shows in HD.
post #339 of 409
A station does not require to have its local news in HD to air these two shows in HD, although it doesn't hurt. What is required is a HD satellite receiver and a method to record the feeds and play it back later. This can be a HD tape machine or a server. The HD satellite feed is not intended to be aired live. The feeds are in the morning/afternoon. Eventually these shows will probably be distributed the same way the SD version is, which is via Pathfire.
post #340 of 409
Our local CBS affiliate is the only one in our market doing local news in HD. Wheel & Jeopardy are on our local ABC affiliate in HD. So just adding another to the "no requirement" answer.
post #341 of 409
Our local ABC channel, KGO, had Jeopardy and Wheel of Fortune in HD long before our news got there. Happily it's all HD now.
post #342 of 409
Our ABC station Records The Satellite Feed And Airs it an Hour Latter, So Shouldn't KDBC do the Same Thing.
post #343 of 409
I've seen this rumor too many times. KOMO in Seattle does NOT broadcast their news in HD. It's extremely clear 16x9 SD. KING is the only Seattle station with news in HD. And no, Jeopardy and Wheel are still not in HD on KOMO yet.
post #344 of 409
Jeopardy is FINALLY in HD in the Boston market! I noticed it last night for the first time. It looked great.
post #345 of 409
Yes, I saw that a week or so ago. Wow, what a difference. I haven't checked out Wheel, though. Has that made the transition yet?
post #346 of 409
WLOS began airing both shows in HD on May 27th. Hallelujah!!!!
post #347 of 409
WABC-DT via Cablevision.
Just noticed that the Saturday syndicated shows of Jeopardy and WOF are now in HD. I'm pretty sure they weren't before today, at least on WABC.
post #348 of 409
Beginning in September north of the border, both of these shows are switching networks -- from CTV to CBC (Wheel) and from Rogers Stations to CBC (Jeopardy).
With CBC being an HD carrier, I'm not even a bit concerned if we're going to get these in HD. The Rogers stations have never shown Wheel in HD. CTV continues to show Jeopardy in HD.
The bigger debate up here is why a publicly-funded broadcaster is suddenly expressing interest in U.S.-produced game shows (but I think we should leave this to other forums)
post #349 of 409
I have seen it in HD before...I think it just depends on what the air date of the episode was. I believe they sometimes air shows from they went HD.
post #350 of 409
They've been in HD on WABC-DT from the first day they went HD, which was in September 2006. It has been almost 2 years and you just noticed.
However they sometimes repeat shows more than 2 years old which are not in HD.
post #351 of 409
WOF is still SD here on the weekend, including episodes that were originally in HD.
post #352 of 409
It's still not in HD in the Lafayette, LA market
post #353 of 409
Still waiting for Jacksonville, FL to see the light for any locally generated HD programming or syndicated ones. Hopefully things will change by the time they have to turn off their analog channel in February.
post #354 of 409
Ditto in DC. Perhaps someone from WJLA can explain why, please?
post #355 of 409
10/31 Halloween Jeopardy! not in HD.
WABC screwing up or something wrong with this episode?
EDIT: WoF in SD, also.
post #356 of 409
10/31 Halloween Jeopardy! not in HD..
HD here from WOLO-DT..
post #357 of 409
Must be a screwup at WABC because both Jeopardy and WoF are not in HD on my local from Directv either.
post #358 of 409
KNSD-DT is now airing both WOF and Jeopardy in HD. Wheel was added on 12.03 and Jeopardy was added the day after.
post #359 of 409
I don't think I'm watching Jeopardy! and Wheel in HD on WAND 17(a Decatur, IL NBC affiliate). I get my locals in digital now(since WAND 17(NBC), WCIA 3(CBS) WRSP 55(FOX), and WCIS 20(ABC) made the switch this month instead of waiting untill the new June date through Dish Network(not antenna)...and yes I do pay for HD programming. The Price i$ Right looks nice in HD(but noticed that during it and other HD shows on CBS the screen will go black for a nanosecond once in a while. But to stay on topic, Jeopardy and Wheel sadly seems to be only in SD 4:3 pillarbox and I think only Dolby Digital 2.0. I wish I could be watching it in 16:9 1080i(if it's recorded in that resolution and aspect ratio), Jeopardy has to be my favorite show.
Speaking of gameshows in general... Does anyonyone have any insider knowledge of if and when GSN will be in HD. I really like watching the Match Game and the Richard Dawson hosted Family Feud(I can't/couldn't stand Ray Combs, Louie Anderson, Richard Karn and John O'Hurley).
post #360 of 409
Match Game and Family Feud were recorded on tape in SD resolution and, as a result, can never be in HD.
  Back to Forum: HDTV Programming
