AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Programming a remote for a Vizio TV???
Programming a remote for a Vizio TV??? - Page 5
post #121 of 126
Originally Posted by Edmund View Post
Program it for what, it can't be programmed its single device remote, a Vizio tv, sorry.
So then this remote prolly doesn't work for my tv?
post #122 of 126
According to the pdf I saw of your tv model, the remote looks like this:
http://www.ebay.com/itm/VIZIO-VR2-TV-Remote-Control-for-VECO320L-VECO320LHDTV-VECO320L1A-VO320E-VO370M-/190780546788?pt=US_Remote_Controls&hash=item2c6b681ee4
post #123 of 126
but it compatible for VIZIO VECO320L VECO320LHDTV VECO320L1A VO320E VO370M VO420E
not my VIZIO VX32L HDTV10A..... and that remote doesn't match the one I have here....
post #124 of 126
You did try the remote? Did it work?
The remote comes with all kinds of models, see here:
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=0980-0305-3000
post #125 of 126
I tried the remote didn't work. I contacted the seller for troubleshoot was told that it should work right away doesn't need programming it... I don't know but did some research for this TV and yes that remote should look just like that for this TV.And this remote I have is compatible for mine but I don't know why isn't working or maybe it NOT compatible and seller is wrong? Does my TV need some factory reset or something?
post #126 of 126
Do you have another remote, like a directv, cable or some other universal remote? If so, list them, perhaps we get that working. It also might be the tv, it maybe broke, it is 2008 model you bought used.
  Back to Forum: Remote Control Area
