Originally Posted by Kupakai
Try this to assign DVD input to a key:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 994
4. Press and release SETUP
5. Type 00249
6. Press and release the button you want to assign the function to
The remote should blink twice if programming is successful.
Repeat the above steps for the other input selection keys and use the codes below in step 5:
Tuner = 00057
AUX = 00121
I found these from JP1 site's[/url] upgrade files for similar models, but I haven't found one for USB, which I think your model has.
EDIT: I just looked at a similar model of Samsung HT device and I guess USB is accessed through the AUX button. Is that correct?
3. Type 994
5. Type 00249
Tuner = 00057
AUX = 00121
That is correct. It worked like a charm!!!! Thank you for your help.
