AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Programming a remote for a Vizio TV???
Programming a remote for a Vizio TV??? - Page 3
post #61 of 126
Does anyone have a generic code for the Samsung HT-WZ410 Home Theater that will allow me to use the Vizio remote to control the Samsung?
I called Vizio and the tech that I talked to sounded like he was in the middle of a restaurant. It took me three times explaining what I was looking for before he got what I was talking about. Honestly, it sounded like he didn't want to be bothered, and as such, was no help at all. I know that a lot of times there are other component model codes that might work. He said to call Samsung.
I called Samsung, and they didn't have a code, so I am back at square one. I've already tried the 9-9-1 search with the Vizio remote and came up with nothing.
Any other ideas?
post #62 of 126
Unfortunately, this didn't help me, but it might help someone else. I went through the Vizio discussion forum, and apparently, they forgot to put the codes into the manual.
Components codesPosted June 05, 2008 - 02:17 PM by VIZIO-Guru
Posted June 05, 2008 - 03:07 AM by soNso
Hi... just got a vp504 & everything great but i must be missing something. i don't understand how to program my receiver, dvd, cable box w/o any codes to try. HELP!!! Thanks
There was an error in the manual there that caused the remote codes to be left out. You can use the codes from this PDF for the GV52LF as they are the exact same codes you would have had if the error had not taken place.
vizio.com/media/products/pdfs/GV52L+FHDTV+User's+Manual(1).pdf
Also those programming instructions for the remote will work as well. Sorry for the trouble!
post #63 of 126
Sorry it took me so long to get back to you.
First here are the codes listed in the book: 31023, 30153, 30014, 30630, 30531.
This for Pioneer audio/amp section.
I own a Pioneer VSX-812 Home Theatre system, but the Pioneer itself is really a big amp/receiver with a lot and I mean a lot of input options.
Thanks Rob
PS Someone said this remote is made by a company called UEI. If thats true do they have a website that might list all the options this remote can do?
post #64 of 126
Just started with Comcast HD Cable and Visio 32" TV. Read the threads and tried the 0178 code, but the 3in1 controller wouldn't accept it. Tried the other 4 number codes and no luck. Did the key find option (tv power) till my fingers were bleeding and no luck. Is there some other lock/unlock that allows the 3in1 controller to be reprogrammed. All in want is power and volume for the TV on the 3in1. Friend had same problem and he went and bout a 6 in 1 with the ir learning feature and had good lunk, but would like to use the controller I alsready paid for. Thanks in advance.
post #65 of 126
Try it with 5 digit code, like 10178, 10056.
post #66 of 126
1. Comcast has no clue how to solve my code issue for a visio TV. When I load in the code, like 0178 I get no response - not a double blink (good code) or a single blink for a bad code.
I thought the controller would not care what code was entered as long as it was a four digit one. Since I get neither, I assumed the controller must be defective, but they say (online chat with human) that the controller is OK, with the only issue being that since the visio is not listed as a brand in the contoller list, it cannot be accepted by or programmed into the controller.
Is this true?
When I tried the retreive the code option for the TVbutton using 991 i did not get a double blink, I assume that means there is no code entered for TV.
Rest of controller functions seem ok. Is there a way I can just program the volume and power functions in the controller and not use the TV brand function number (like 0178) Can a contoller have both 4 and5 digit codes.
post #67 of 126
My controller is for the DVR 3 "On Demand" Device and not the Custom 3 "On Demand" device. It first is a 5-digit code and the second is a 4-digit code for those who ever get in same situation, Visio is listed as a supported TV with for the 5-digit device with codes of 10864, 10885, 11756, and 11758. Will see if they work this PM. No more replys from me mean they did work. Thanks for the Help.
post #68 of 126
11758 for a new 32" Visio HD LCD running on Comcast HD DVR Remote. Life is good.
post #69 of 126
I am using the 0178 code and was wondering if there is an advanced code to enter the - for digital channels on the remote?
post #70 of 126
Try 00018
post #71 of 126
Thanks that worked great!
post #72 of 126
Is there an Digital Audio Out Mode (Dolby Digital, PCM, Off) program code for the Vizio/0178?
post #73 of 126
Here are the advanced codes for all of the known Vizio functions:
00181 - Channel +
00185 - Channel -
00183 - Vol +
00187 - Vol -
00053 - Power
00057 - Mute
00055 - MTS
00059 - Audio
00054 - Sleep
00117 - 0
00121 - 1
00119 - 2
00123 - 3
00116 - 4
00120 - 5
00118 - 6
00122 - 7
00245 - 8
00249 - 9
00247 - Last
00251 - Info
00244 - Guide
00216 - Exit 2
00090 - Input
00025 - CC
00165 - Zoom +
00169 - Zoom -
00171 - Menu
00164 - OK
00168 - up arrow
00166 - down arrow
00170 - left arrow
00037 - right arrow
00041 - Exit
00105 - AV
00231 - Component
00197 - PIP
00201 - PIP Size
00199 - PIP Input
00203 - PIP Ch -
00196 - PIP Ch +
00200 - PIP Freeze
00198 - PIP Swap
00202 - Mode
00138 - Wide
00253 - RGB
00174 - HDMI
00110 - TV
00018 - dash
post #74 of 126
How do you program the Power button? I know I have the right code because if I assign it to another key it properly turns off my device (in this case, a Logitech Z-5500). However, when I go through the steps and press the Power button as the key to assign it to, it blinks at me once in error. Any ideas?
post #75 of 126
Which remote are you trying to program? It sounds like there's a restriction programmed into your remote that is preventing you from programming a keymove to the POWER button. Can you program macros to the POWER button? If so, maybe you could designate another button as the pseudo-power button and then program a macro on the real POWER button that calls the pseudo-power button.
post #76 of 126
Here's a photo of the remote I have
I haven't tried programing a macro, I am not sure how to do that. Thanks for any help you can provide,
post #77 of 126
Anyone know the code for a Dishnet ViP722 remote that will allow it to toggle the inputs on a Vizio VOJ37 LCD TV? I can control ON/OFF & VOL.
Shorty
post #78 of 126
The code for my Vizio VO42LF 1080P LCD that correctly programmed my Comcast universal remote was 0178. Hope that helps!
post #79 of 126
I have a Pioneer VSX-918V Tuner. I used 610 to program the remote to turn my Vizio VW32L on and off.
post #80 of 126
Hello all,
Code 0178 worked perfectly for my non-HD Comcast cable box.
Code 0035 worked perfectly for my new HD Comcast cable box.
(Provides basic controls: on/off, channel up/dn, vol up/dn, menu, etc)
Note: Vizio is not listed on the Comcast list but "Sears" is listed so you may want to try some of thier codes if all else fails. Here's the codes for Sears:
0035, 0037, 0047, 0000, 0042, 0104, 1237
Good luck,
gustavio
post #81 of 126
I am hpoing someone out there has a solution for me. I recently got both a Vizio 50" plasma and Comcast HD. Using the remote for all basic functions is fine. My issue is whenever I adjust the volume the volume will again adjust (up or down depending on which direction I had just adjusted it) whenever I press ANY button on the remote. This has gotten very irrating and comcast has no answers for me. They suggested switching out the remote and that has done nothing. Any suggestions?
post #82 of 126
I have an RCA universal remote that controls 6 devices and a brand new 37" Vizio TV that I can not get programmed in- Any other codes to try or any ideas on what I am doing wrong?
post #83 of 126
try the Goldstar tv codes.
post #84 of 126
I have a kind of universal remote with my panasonic dmp-bd60 blu ray player. I tried the 0178 code for my vizio and everything works well except the input button which is kind of annoying since it allows to switch between tv/hdmi's.
Any clue on how to handle that. I tried the thing of Kupakai on the first page but since I don't have the same remote I don't have some of the keys that are on the hint. So it's not working
post #85 of 126
Zenith code 1357 just worked for me. controls power and volume anyway.
post #86 of 126
Just bought a 47in Vizio and programmed the Comcast remote to 0178. It all works great. Thanks.
post #87 of 126
Vizio VO42L and Comcast DVR remote, TV code 11758 works and is fully functional (Menu, arrows, etc..) without requiring advanced setup.
post #88 of 126
Originally Posted by Kupakai View Post
If you are using TV/0178, do the following:
1. Press and release TV device key
2. Press and hold SETUP until remote blinks twice
3. Type 994
4. Press and release SETUP
5. Type 00090
6. Press TV/VCR key
The remote should blink twice if successful
You can also assign the following to other keys (the number is for step 5, and choose whatever key you want for step 6):
Wide = 00138
TV = 00110
AV = 00105
Component = 00231
HDMI = 00174
Hi all, I tried all of this, and it didn't work.
I have a Radio Shack 4-1 remote (0178 worked for my Vizio), the only difference being that it's labeled P instead of SETUP. The TV/VCR button is labeled the same, but I can't get it to change from it's current function, which is to change the audio (stereo/mono/SAP). Looking for help to get it to change to Input. Please and thank you in advance!
post #89 of 126
I didn't think starting a new thread was warranted because I see people trying to do the same thing as I when I search the forum. The unofficial "Official Vizio TV" thread had similar posts but this thread seemed more relevant.
Attempting to program an MS XBOX Universal remote with a Vizio VZ32LHDTV10A. I've tried the below listed codes:
Vizio 3 Digit Codes
627, 502
Vizio 4 Digit Codes
0030, 0056, 0117, 0128, 0205, 0279, 1756, 1758, 0178, 0153, 0790, 0791, 1017, 1292
Vizio 5 Digit Codes
10178, 10117, 11756, 11758, 01377, 10885, 10864, 10120
None of them seem to work and I tried searching using the XUMR's search function. I have been unsuccessful to this point. Is there some setting on the TV that needs to be configured or a firmware update to the TV that should be applied for any of these codes to work?
I am putting a post in to MS as well to see if they have an answer. Hope to get a reply.
Thanks in advance
post #90 of 126
If you tried all the codes and none worked, there's nothing more you can do, unless your remote can learn. You're wasting your time with any codes that weren't in the printed instructions that came with your remote. I don't know where those codes came from but most of them aren't vizio codes and are for entirely different remotes. The only vizio codes I see are (1)1756, (1)1758, (1)0864 and (1)0885 which are for one-for-all remotes, not MS. There is zero chance they will work with your remote.
Anyone reading this post that has a remote from one-for-all, radio shack, comcast, charter, etc. could also try (1)1499 and (1)1755 (the 1 in parentheses is for 5 digit codes. Leave it off for 4 digit codes).
I suggest you get a universal remote to replace the MS and Vizio remotes.
  Back to Forum: Remote Control Area
