Originally Posted by egravel
duffman64:
Do you know what timings you're using for 1360x768? I have an nForce2 IGP (i.e. GeForce4 MX) and have finally gotten the "default" 1360x768 res to work well (i.e. no custom res) by changing the timing mode to DMT (Discrete Monitor Timing). See here in Advanced Timing:
http://www.nvidia.com/object/advanced_timings.html
If you have the latest drivers, the GUI will be a bit different. I tried manually adjusting it myself, and finally just decided to try the defaults with the default res, and it worked with DMT (though YMMV).
By the way, it HAS to be 60Hz. That's what this set is rated at.
Also, this res fills the screen, and overscans by a few pixels on all sides, so you won't see your full desktop. I get about 5 pixels less on top, 3-5 on each side, and a few more on the bottom, that are missing. If you find a way to solve this let me know!
duffman64:
Thanks egravel This worked well. I am considering buying a monoprice hdmi switch for this. The ~$130.00 investment would allow me to run almost everything through the hdmi port. But this worked an I may hold off on that. The DVI picture is much clearer but this is pretty good.
but whats interesting is the returns guy did say they had already received 2 other sets making mine the 3rd set back to Costco (Sacramento, CA area) .The other 2 had come a day before so somethings definitely up on the build quality (and satisfation factor) of the Komodo.
