AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic TH-37PX60U Input Question
post #1 of 2
I purchased this PDP for a retired priest friend of mine. It will be delivered Thursday. Since there is only one RF input, is there a way to input cable and OTA at the same time? I read the manual and it shows that you must, via the setup menu, designate whether you are inputing cable or OTA. I want to keep this as simple as I can for the Monsignor. Thanks.
Jim
post #2 of 2
Unfortunately, cable and OTA frequencies overlap, so cannot be used at the same time. This is the reason for the restriction. One common workaround is to use a VCR as a tuner and go into another input.
This thread is locked
