AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Quick Panny TH-PHD8UK connection question
post #1 of 3
After having the panel for about 9 months, I just got my HR10-250 Directv Tivo hooked up, and now have a question about the best way to connect it, and my DVD player back to the panel. I just connected the Tivo via the component cables since I never got around to purchasing an HDMI blade/board.
My question (okay, okay, 5 questions) is, do I need to buy an HDMI blade? Can I leave the Tivo hooked up via component and then run the DVD player via component-to-VGA cable to the PC in slot? Will the PQ be better on the Tivo if I use HDMI instead of component? Is there any difference in PQ between straight component/component vs. component/VGA?
I don't mind purchasing the HDMI blade, but if I don't have to drop $140 on it, then all the better.
post #2 of 3
I'm using both component inputs on mine and can't tell the difference. I'd try the VGA cable before the blade but most HDMI blade owners like the PQ slightly better than component.
post #3 of 3
Thanks for the response. Unless there are any dissenting opinions, I think I will go that route first.
I have read the debates on component vs. hdmi and it seems that hdmi wins by only a slight margin. If so, I'm not sure my eyes will be able to tell the difference.
This thread is locked
