AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › WARNING my Avdeco Plasma TV stand EXPLODED (Pictures)
WARNING my Avdeco Plasma TV stand EXPLODED (Pictures) - Page 6
post #151 of 183
Originally Posted by Free View Post
By the way, just to update everyone, here is what I replaced it with. I think this should hold up.
Phil quick question for you. Your new stand I hope that its opens at the back as a plasma generates heat and you need a open back space to vent out.
A plasma cannot be installed in a closed in cabinet. I presume from your old photo the new cabinet just covers the front and open design at the back?
Glad you were able to get the replacement glass and nice new cabinet.
post #152 of 183
Everyone should note that the design of this particular stand is the culprit. Never secure glass with anything other than the weight of the glass, and then only using enough supports to overcome large bending loads. Glass is wonderful for compressive loads, but lousy when under bending, especially when it is secured by fasteners that go through the glass, as the damaged glass photo seems to indicate. Glass does not expand under heat, to the same degree, as metal does. A good design allows for a way for the metal stand to move under the glass, without placing undue forces on the glass. All bolts that are used to assemble the unit should be left hand-tight prior to placing the structure in it's intended location. Then tighten the structure, so as to make sure it is flat on your floor. A slight load, from the glass, is preferred, as well as tightening from the inside to the outside of the support structure, in a "star pattern". Then, place your Plasma on the unit. Go back in a month, and check for loose fasteners.
I also have renters insurance, which offers me peace of mind. My two cents - Materials Engineer
post #153 of 183
You totally lost this non-mechanically inclined idiot.
What should we be looking for in a glass stand to make sure it can take various flat-panel loads of from 80 - 200 pounds, which are what the 42"-63" models weigh?
Is tempered glass a panacea?
I have the Z-Line model from CC with a 95lb. 42" plasma on it -- should it be OK ?
post #154 of 183
Freyes is absolutely right. That is a terrible design. Seems the designer was only interested in form and had no interest in a sound engineered design. The first thing I noticed when seeing the photo is that the glass had a free span all the way across w/ no intermediate supports, and appears to just be slid into the slots cut into the metal posts. Terrible on both counts. I just purchased a wood / steel / glass stand to go w/ my new Sammy plasma. The stand has a large plate of glass on top supporting the tv, but it has intermediate supports which cuts the span way down, and the glass simply rests on silicone pads. It isn't fixed or bolted down in any way, nor does it touch the steel frame. People shouldn't be afraid of glass tv stands, just choose a sound design.
-Gunner - Structural Engineer
post #155 of 183
Hmmm...I guess I should have consulted with a Structural Engineer before making the purchase.
post #156 of 183
Lol. That might be overkill - but - AVdeco obviously needed an engineer to review their designs.
post #157 of 183
Gunner, thoughts on the Z-Line? The manual said OK up to 340 pounds or so, I have my 42" weighing just under 100 pounds on the top shelf and VCR/DVD/STB on the middle ledge weighing maybe another 30 pounds, tops.
post #158 of 183
Link ?
340 lb - wow. Who the hell has a tv that weighs that much? : D Or is that total weight for all shelves combined? Look to see if the documentation has a 'top shelf' load rating. 100 lb isn't too worrisome, assuming its a quality design.
I went with this stand for its 3-in-1 configurable design, and its aesthetics. Looks sharp in person : http://www.bestbuy.com/site/olspage....=1179876185999
post #159 of 183
Gunner, this might not be the exact model (weigh max is lower) but it's close enough I guess:
http://www.circuitcity.com/ssm/Z-Lin...oductDetail.do
post #160 of 183
Yeah that looks too small for your 42" tv.
Sure its not this one ? This one says the TV shelf is rated at 300 lb. http://www.circuitcity.com/ssm/Z-Lin...oductDetail.do
Regardless, it looks like the glass is just resting on the supports, not having fixed connections (which is a good thing). And there appears to be intermediate support for the glass, instead of a full span from one edge to the other. I wouldn't be worried about it.
post #161 of 183
That picture link no longer works.
post #162 of 183
*cringe*
I just brought home my Pio 6010 last night. I also already bought a Sanus VMPL3B. It will be a little while before I have everything ready to mount on a wall though.
I have this stand by Z-Line from when I had a Sammy DLP but am now seriously afraid to have the plasma on it. I planned on using this stand for about a month until I can wall mount the Pio. The Pio weighs ~140lbs with the stand (very wide stand) and the tv stand says it supports 240lbs.
I was thinking about cutting a sheet of OSB to fit the top of the glass perfectly, paint it black, and set the tv on top of the OSB on top of the glass to distribute the weight better (more to the supports). Does this sound fine or should I feel fine using the glass by itself?
post #163 of 183
I don't know about you but I will never use glass again.
post #164 of 183
does anyone have a current Phone# or weblink re AVDECO.
I have a rack and need to ask a question.- the ones here on avs are dead.
db
post #165 of 183
I just wanted to post an update to my situation, and let everyone know that Paul came through for me, and a replacement glass top was delivered yesterday. He went out of his way, to take care of me, and is a good guy.
Just curious,your home insurance would not cover that ?
post #166 of 183
My deductible is way to high to cover it.
post #167 of 183
But would they cover if the TV was FUBAR ?
Now I'm afraid I got this one ---> using on a Sammy 58A650 I hope it holds.
post #168 of 183
Fortunately my TV was fine, so I didn't have to find out.
post #169 of 183
I was told to steer clear of glass (I asked because I have two boys under the age of three). It may be rated for load-bearing a specific weight, but the rep we talked to said hitting the edge with a sharp, hard object can cause them to literally explode. We bought a Techcraft BAY4632 just to be safe. That is one very shocking photo. I am glad no-one was injured firstly, and secondly that the plasma survived. Acrylic supposedly is much preferable to tempered glass, but is very expensive.
post #170 of 183
Pretty lousy after sales support, and they only replaced it because of these forums. I have been worried about glass shelves and heavy items, especially once you go over 20 or 30kg. I can't understand why all glass shelves don't have a metal frame either around the edge or a X like Apollo Aria range. Apollo have a range like the OP- Soprano, just held by 4 holes/struts in the glass, all that weight is the four corners.
Also reading about the small area on the plasma stands and how it may be only be in contact in a few small bits of rubber, good point and I didn't think of that. If you were to place another piece of glass exactly the same size, but heavier than the plasma it'll take more weight, until it finally smashes. So you need to spread the load on the item itself, and the mountings for the stand. So that X underframe is a best idea, the plasma stand will be directly above the X, so any downwards force is spread on the X, also overall the weight is spread on the X as well, the X metal frame is the bit taking the load.
post #171 of 183
ya mine just did the same, came on here, saw your post. i was in the other room when i heard it explode and crash. when i went in to investigate, all the glass was still popping and exploding like pop rocks but bad enough make the glass stick in your skin if it hits it. what the hell?!
post #172 of 183
is the TV ok?
post #173 of 183
I had forgot about this thread but it only reinforced why I will not buy glass stands. I cannot imagine the horror if my Kuro went crashing down onto my other expensive components.
post #174 of 183
like has been stated in this thread dozens of times, not all glass and metal stands are created equal. i have been using the same glass and metal stand for the last 6-7 years without any issues. it is built a lot better and has more even support than that stand. i fully trust it with my 58" plasma.
post #175 of 183
Glass has 0 degrees of give to it and has various places which are weaker than others. The thicker the glass usually the stronger. However, thickness does not eliminate breakability.
Also keep in mind that items placed on a glass stand are not equal in weight in all places. so there might be more pressure or weight on certain places of the glass.
post #176 of 183
Holy old thread!!!
post #177 of 183
I just had a similar experience myself. I've got a 50" Philips plasma TV on a glass and metal stand. Not sure what brand of stand mine is, actually - but I believe I purchased it at Ultimate Electronics a couple years ago, when it was on sale. (There weren't a whole lot of options available locally for 50" TV stands at that time.) This one looks similar to the Z-Line 3 shelf stands other people are linking to photos of, but the metal frame is a little bit different.
Anyway, my stand has been fine, until my g/f's 3-year old daughter got mad about something the other night, and threw a ceramic coffee mug across the living room. It hit the edge of the middle glass shelf, causing it to explode instantly. (The mug, however, is fine... go figure.)
I was *really* glad it didn't hit the top shelf that the TV was on! My Playstation 3, VCR/DVD combo unit, and some DVDs were all that fell to the bottom shelf, and they all survived. Lots of little glass "pebbles" and fragments to vacuum up though!
But whoever said their salesperson steered them away from glass shelves if they had kids in the house? Great advice! It's true that these shelves shatter EASILY when stuck at just the right angle!
post #178 of 183
Anybody got any thoughts on wood ?
I have an Avondale corner stand from Bob's Discount with 3 drawers.....it has the gap between the top shelf where my 42" sits and the drawers, which is empty space (good for my DVD or STB; bad for support).
http://www.mybobs.com/Avondale.aspx
My plasma weights 100 pounds and it can NOT reach across to the reinforced ends of the furniture (just short -- the stand is 32 1/4" and the furniture is 35")
BTW, the thickness of the wood is 3/4" thick. Not sure what kind of wood it is -- it doesn't appear to be redwood or oak but it 'aint balsa, either.
post #179 of 183
Anybody think 100 pounds is OK for that stand above ?
post #180 of 183
I wouldn't think it would be an issue. I'd be more worried about the stability (tipping) than crushing the stand.
