AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official Yamaha RX-V1700/RX-V2700 Thread
The Official Yamaha RX-V1700/RX-V2700 Thread - Page 175
post #5221 of 5236
Originally Posted by SwitchbladeHD View Post
I'm selling my RX-V2700 for $400. with free ground UPS shipping (USA states only). It's in perfect condition and I've never had any issues with it.
Based on ebay sells of units in great condition, this is a good deal. You can find them cheaper, but with dings and who knows how they were treated. Mine has not one mark. I have the config mic and manual too.
PM me if interested.
Thats a good price
Seen some here in Canada trying to get 700 but for the most part it ain't gonna happen
post #5222 of 5236
Originally Posted by tyreman View Post
Thats a good price
Thanks. I'll do $375. and you pay for shipping to Canada, and it's yours. smile.gif
post #5223 of 5236
Let's see if I do this right..
Just stumbled unto this forum.
I have an RXV2700 that has never been set up correctly.
I don't have time and I also do not understand all the jargon.
Is their a PC setup utility available that will making setting up less painful and allow me to get the best out of this unit?
I'm also led to believe that the firmware/software can/should be upgraded.
How do I check the version and how do I upgrade if necessary?
Lots of questions with answers possibly in the 175 pages of this thread.
Help, please?
Kobus
post #5224 of 5236
It has a built in-auto setup (YPAO). See page 35 of the 2700 manual (which you can download from any Yamaha web site if you don't have it). You need the microphone that came with the the 2700, otherwise you have to set it up manually. There's nothing for a PC that can help with the setup.
YPAO is not foolproof, so you need to check a few things after running it. In some cases the correct settings are going to depend on what speakers you have. e.g. in most cases all speakers should be set as small if you have a subwoofer, but they might get set as large by YPAO.
Not sure about the latest firmware version.
post #5225 of 5236
I own a 2700..... are you using it for surround sound? 2 channel?.... That model is over 5 years old. While still a keeper, there is no easy way to set it up....TEll us more about your intentions.....rolleyes.gif
post #5226 of 5236
Hi All, this is my first post.
I have a rx-v1700 that has suffered some water damage on the DSP circuit board and now the front right channel is not working.
The repair costs are too expensive at the moment so I was wondering if anyone has a broken reciever (with a different fault) that they would like to sell so I can strip it for parts? I know its a long shot but I thought its worth a try
I live in newcastle australia
post #5227 of 5236
See post 3845 for FW verification and updating (four year old info, posted links within post may not work):
http://www.avsforum.com/t/713397/the-official-yamaha-rx-v1700-rx-v2700-thread/3840#post_12776439
post #5228 of 5236
Hi there. I have a rx-v2700 receiver and the zone 2&3 function has stopped working. I have tried a system reset to no avail. I tried to use the link on this forum to a firmware update, but the link is no longer valid. Does anyone have the latest firmware for this receiver that they could share? Failing that, is anyone aware of what would cause the zones to stop working? Thanks
post #5229 of 5236
Here is Yamaha's tech support # 714-522-9105.....MON-FRI 8-4pm. OR 866-866-4616, OR 800-292-2982
Here is the Yamaha website for the firmware update I used sometime back:
WWW.YECSUPPORT@YAMAHA.COM.
i USED VERSION : KO(ZERO)52/I(EYE)O(ZERO)44/3.O(ZERO)R,
BUT RUMOR HAS IT THAT A FORMER ISSUE WAS ALSO AVAILABLE: K052/L047/4.2r
THERE MAY BE LATER VERSIONS....BEFORE I DO ANYTHING TRIPLE CHECK WITH YAMAHA !!!!!!!!. OR YOU'LL WIPE OUT YOUR MEMORY.......!!!eek.gif
'FURTHER QUESTIONS... i COULD SCAN THE DATA i HAVE AND EMAIL IT TO YOU....
G;)OOD LUCK!
post #5230 of 5236
Thank you for the reply. I scoured that site and the US site but there was no firmware update. I am in New Zealand, so I will try the NZ distributor first and then call the States if I have no luck
post #5231 of 5236
I sold my RX-V2700, but here are the latest firmware instructions and I have attached what I think is the last update (44). I never did update my unit, as it wipes out some of the settings and from what I read, it only fixed a few minor things. USE AT YOUR OWN RISK - DO YOUR OWN HOMEWORK!!! That said, I did obtain these instructions and the firmware file directly from Yamaha's website about 1 year ago.
RX-V2700 FW UPDATE INSTRUCTIONS for 0044 FW version:
0044 file version = R061/L047/4.5r on your 2700
Carefully follow the RX-V2700 firmware instructions to complete the update. If you’re
experiencing problems with the firmware update, FIRST refer to the FAQ’s listed at the bottom of
the RX-V2700 Firmware update instructions page. Otherwise, contact YAMAHA Electronics
Customer Service Department support line by dialing (800) 292-2982 (800) 292-2982 Monday through Friday
from 8:00 a.m. to 4:00 p.m. PST for further assistance.
INSTALLATION DIRECTIONS:
1. Connect the power cable of the main unit to the AC outlet.
2. Please make sure that the MASTER ON/OFF switch is turned OFF.
3. Press the “MASTER ON/OFF” key of the main unit while simultaneously
pressing the “STRAIGHT” key of the main unit. Then the ADVANCED SET-UP
mode is activated.
4. Press the “NIGHT” key of the main unit for about 5 seconds.
5. Turn the “PROGRAM” know to select USB.
6. Press the “NIGHT” key on the main unit.
7. Insert the USB flash memory to the USB terminal of the main unit. (Writing of the
firmware is started. It takes about 10 seconds before the writing is started.)
8. When writing of the firmware is completed, the power of the main unit turns
OFF/ON automatically and back to the normal mode.
NOTE:
The “Firmware Update” process will take approximately 45 minutes to complete. Once the update is
complete, the receiver will shut down and then power back on by itself to show completion of the update.
FIRMWARE VERIFICATION CONFIRMATION:
To verify the firmware version, please follow the listed steps below.
1. Please make sure that the MASTER ON/OFF switch is turned OFF.
2. Press the “MASTER ON/OFF” key of the main unit while simultaneously
mode is activated.
3. Wait 2 minutes while the receiver processes the firmware version.
4. Hold down the Enhanced Button for approximately 5 seconds.
“Firmware Version Number” is displayed (R061/L047/4.5r). If you see (R061/----/4.5r),
please wait for 2 minutes then re-check. Your RX-V2700 receiver is now updated.
And then I had another doc for checking to see what firmware you have:
mode is activated.
“Firmware Version Number” is displayed (K052/L047/4.1r). If you see (K052/----/4.1r),
Enjoy
RXV2700-0044.zip 4603k .zip file
post #5232 of 5236
Hi There,
Where can I get the firmware image in order to update the RX-V2700?
Many thanks
Pierre
post #5233 of 5236
Originally Posted by pierredp View Post
Hi There,
Many thanks
Pierre
post #5234 of 5236
Thank you very much SwitchbladeHD
post #5235 of 5236
post #5236 of 5236
Ha ha, how did I miss that :-).
Many thanks,
Pierre
