In another thread, the highly respected Sanjay Durani makes the following comments, (re-quoted here so as not to hi-jack that thread):
Sanjay,
Could you go into a little more detail about this? What is it about lining the speakers up in a cabinet that causes the effect you're describing. Is it diffraction off the cabinet or interaction between the speakers? Also, is there anything a speaker designer can do to overcome this phenomenon, such as playing with the polar radiation pattern, or some phase relationship in the crossover, etc.?
Here is another possiblity: my CC has what Klipsch calls a tapered-array crossover where one of the woofers is crossed at 550 Hz and the other at 1950. From the Klipsch website:
If I wanted to measure my CC to see if it has the effect you describe, could I take my SPL meter and move it around the speaker in the different planes while playing pink noise? Then reorient the speaker vertically and repeat the measurement?
Thanks for your always insightful help.
Craig
Originally Posted by sdurani
The thing about lining up drivers in a speaker is that the sound cancels in the direction they're lined up in but remains unrestricted in the opposite direction. Follow:
If you were to place the centre speaker with the drivers lined up horizontally, they would cancel in the direction of the drivers (listeners on the left and right of the sweet spot would not get good sound) and be unrestricted vertically (giving you reflections off the ceiling and floor, which would muddy dialogue clarity). Talk about a lose-lose situation.
Compare that to rotating the speaker so that the drivers lined up vertically. Sound would cancel in the vertical direction, for less bounce off the ceiling and floor, but sound consistent horizontally, so all the listeners on the couch hear the dialogue clearly. In short, everything you would want from a centre speaker.
Sanjay,
The RC-7 center channel features Klipsch's version of 2.5-way crossover technology, called tapered-array. With tapered-array, the two Cerametallic woofers work together to deliver high impact bass with one driver transitioning out at the mid-range frequencies. This provides more consistent coverage across the listening field, less tonal error and improved dialogue intelligibility.
The high quality crossover networks of the RC-7 are carefully designed for an improved blend between the lower midrange and upper bass frequencies.
Craig
