Hi there, as far as I know, and forgive me if I'm wrong, DVD assist is designed to run under Tiger and not Leopard, the main reason there isn't Leopard compatibility with DVD Assist is because Leopard plays Video_TS files in Front Row.
ISO files as far as I know aren't compatible with Front Row in Leopard, so I'm thinking you'll need to turn them into folders containing the Video_TS file in order to play them back.
Like I say I could be wrong, but I don't think you'll see DVD Assist getting any updates. There is a plugin for the new Front Row called Sapphire (http://appletv.nanopi.net/), I don't know much about it but it might help with your problem if you don't fancy converting your files.
