Originally Posted by
whowillbe
So do you think its better that I used a line quadrupler instead? Cause in this case, I can simplify the video chain.
no one calls them "quadruplers" anymore, the correct term is Video Scalers
They are the best solution but they start at around $1500. for a good one.
http://www.lumagen.com/testindex.php?module=hdp_details
I like the Lumagen's because they have a 5BNC ouput option which eliminates the crappy little VGA plug. If you buy a used scaler, make sure it's not tool old, you want at least 2 DVI input's. One for cable/sattelite and the other for a DVD player. A Toshiba HD-DVD feeding 720P to a Lumagen and upscaling to 1080P out from 5BNC jacks would be awesome.
The only drawback is the scalers don't accept 1080P in the DVI ports, so if by some miracle Sony Blue Ray turns out to be something other than a pice of shi*t, you won't be able to pass it through/transcode it to RGB. The real problem is that that source technology is changing so fast that manufactuers of set-top boxes are having a hard time keeping up.
So maybe the question to be asked is "what should I do right now"? I would get a Moome DVI card for $200. Plug the Oppo directly into it and set up the machine at 720P, not 1080i.Even though this won't be the best possible solution, If you set up the V1 correctly with a good mechanical alignmentand, correctly adjust the vido levels, G2, etc. there should be no comparison to the Optoma or any DLP for that matter. Then wait for next Spring and the format war to end, dust to settle before upgrading your source to something putting out native HD.
