Can anyone recommend any stores or links that have options for stands for my 42" 9631? Right now, it's on a stand 35" tall which means I am always looking up.
I usually sit in a couch 18" tall which means straight-ahead eye level is 35"-42" for most people sitting down. With the new stand, the 9631 is 33" tall and the TV glass begins at 8" from the base.
I would ideally like something either wood (with draws) or maybe a transparent glass/lucite stand, with room for other components and maybe some TV manuals.
Thanks !
Thanks !
