AVS › AVS Forum › A/V Control & Automation › Remote Control Area › :) Anyone around here got the remote codes for a Mickey Mouse TV and DirectTV?
post #1 of 7
My son has one of those Tube 13" Mickey Mouse TVs and a new DirectTV control box. I read somewhere on the internet that the TV was made by Memorex but, I tried all of the codes from DirectTV for Memorex and could not get it work. Does anyone have any suggestions?
KillerBox
post #2 of 7
If you still have the original remotes..... just use those.
post #3 of 7
If this is the white dtv remote, do a codesearch:
1. Tv
2. press and hold MUTE & SELECT for two blinks
3. enter 991,wait for two blinks
4. enter 1
5. keep pressing and releasing CH UP key, if and when the TV powers off
6. press SELECT to lock in code
post #4 of 7
Try codes 10178, 10171, and 10463.
post #5 of 7
Having the same problem as Killerbox. The codes from Edmund did not work. Any other suggestions?
Greg
post #6 of 7
Greg
How did you test the codes by pressing TV ON & OFF keys? Well use the middle power key in the tv device, along with try all other keys.
The equivalent tivo remote codes to the codes I posted in this thread helped other Disney tv owners:
http://www.tivocommunity.com/tivo-vb...d.php?t=317947
Tivo code 0008= UEI code 10171
Tivo code 0091= UEI code 10463
post #7 of 7
Thanks, Edmund. It turns out the problem was actually with my RC23 remote. Once I reset it, it accepted the 10463 code. That code effectively controls the Mickey Mouse 13" TV on both the R15 and HR20 receivers. Now I need to work on the Mickey Mouse DVD players...
  Back to Forum: Remote Control Area
