From a humble beginning, a theater was born....
After reading thousands of threads over the past several months. I figured it was time for me to contribute. So, here is my construction thread. As you will see there have been plenty of mistakes, poor planning, building, tearing down, re-building. Hopefully, the final product will be tolerable and that slight irregularity of the baseboard trim will not ruin my movie-going experience.
The house is a 2 story with basement that we bought about a year ago. It is 13 years old. The basement was partially finished, but there was plenty of space left over to work with. So why not put in a wet bar and hometheater?
The first part of this thread may go kind of quick. It is not that I am that fast or good at carpentry; I have been working since last Thanksgiving.
For those who are just starting, keep an eye on this thread. I will detail some of the major...let's call them oversights...that the novice will tend to make.
The main room in the finished portion. Kind of rustic looking, the wood panel has to go (and does go)
Ah, the clean palate. Looks like a nice place for a theater. Unfortunately it will only be about 12.5' wide. And the posts will limit the room length.
Another view from the opposite end. Door on the left goes into a closet with the HVAC unit.
Another portion of the unfinished side of the basement. The only natural light in the basement comes through that door. I will try to bring that light into other portions of the basement to make it not feel as much like a basement.
A few more unfinished shots.
The first project, tear down some walls and finish the exercise room/video game room (a man needs a place to play vids during construction). I will see if I can somehow get my original plan uploaded.
and connected it to a 15-amp breaker
??? I guess it made sense to me in terms of creating a "tight" room. If you do it after there is also an extra layer of drywall between the soffits and the rest of the house. I am with you though, it probably doesn't matter. As you can see, I have not un-built my soffits. I am sticking with it as is.
) within the soil in the yard above that wall. It wants to run through (maybe below?) that wall and out those sealed cracks. When it can't go that way it hangs a left and ends up behind the brick veneer and then flows out my door jam. Once again this is all speculation on my part.
