AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Lg Dvd Recorder Model: Dr1f9h
Lg Dvd Recorder Model: Dr1f9h - Page 4
post #91 of 100
Originally Posted by suntzu1 View Post
I have had this DR1F9H for about three months now (it was a gift), all of a sudden it decided that it would not play store bought DVDs. I tried calling LG and they basically said it was me and or my DVDs. What a POS machine and support!!!!
OK, now that I have vented, does anybody have a solution other than throwing this thing across the room?? ANYBODY?
Thanks in advance, sorry about the rant.
Common common COMMON issue with LGs ... you are lucky to get more then a year out of them with no issues ... especially this model ... I can tell you right now your DVD mech went bad, got receipt for when you bought it?? Or can the person who bought it for you get receipt?? 3 months old its still under warranty
post #92 of 100
Originally Posted by bobbilly View Post
Kurt, do you know what the other OP codes are for. Also, do you have a list of the default values for these codes? Thanks
Hi... if you still need this, my default codes were:
71 20 00 49 8F 9E 15 13
post #93 of 100
mine died after about 6 months. no disc found. i will never buy an lg ever again
post #94 of 100
Anyone ever try copying a Laser Disc using this unit. I have quite a number of them and would like to transfer to smaller disc.
post #95 of 100
Originally Posted by Kurt F View Post
2 Hacks in one for the LG-DR1F9H: region free and disable CPRM so you can archive cprm-protected VHS/DVD/Cable/Satellite/etc video onto this DVD recorder, where the cprm copy count would otherwise prevent it.
How to apply: buttons on front panel and remote control.
The 7 0's hack and others listed for this model on the "lock icon" did not work on my LG-DR1F9H (although the 1397139 hack did give me the firmware version info and reset my settings to factory defaults).
So while discovering the way to disable cprm, I ran across the settings for region code in the same area. I changed them both at once using these steps.
CAUTION: These steps take you into a hexidecimal editor where values are changed with the up/down arrows on the remote. DO NOT hit the up/down arrows on your remote until you have FIRST written down the current values (just 8 2-digit hex numbers) which appear when you first get into the hex editor.
1) While the player is on, press and hold both up- and down- channel buttons on the recorder for about 5 seconds (^ & v).
2) A hex editor screen will appear with 8 "OP" codes. The second word in each of these lines is a 2-digit hex number. WRITE THESE DOWN BEFORE YOU HIT ANY BUTTONS ON YOUR REMOTE CONTROL, in case you need to restore them.
3) To disable CPRM, use ONLY the right arrow on your remote (>) to highlight the rightmost digit of OP code 4. Use the up and down arrows on your remote to change this number to it's present value MINUS 8 (if the digit is an A,B,C,D,E,or F; the number is 10,11,12,13,14,or 15, respectively; ie- change a D to a 5). You are in effect clearing the high-bit in this hex digit.
4) To set region 0, use ONLY the right arrow on your remote (>) to highlight the leftmost digit of Op code 6. If this number is 8 or 0, you are already region 0. If this number is greater than 8 (including A,B,C,D,E,F), then change it to 8. If this number is less than 8, then change it to 0. This simply clears the low 3 bits in this hex digit.
5) If you think you might have changed something you shouldn't have, then you can ABORT by hitting the menu/list button on your remote.
6) If you are satisfied with your changes, then hit Enter on your remote to write the new values to ROM. Then hit menu/list to exit.
When you turn your DVD player back on, it will play DVDs of all nationalities and will not prevent recording of CPRM-limited video onto a DVD.
Enjoy :-)
Kurt F
Okay, I'm new, so please forgive me if I missed a solution to this issue somewhere here. I just got my DR1F9H and I cannot record anything, PERIOD! I have tried numerous channels from my DirecTV receiver and I always get the message "Copy protected. Cannot record." I tried the hex editor suggested, but did not get any results. The OP4 code was 49 to start with, so I changed it to a c9 (minus 8 from the previous value, right?) and nothing! I am using a Maxell DVD-RW and VR mode as suggested in the instructions, but nothing! If I can't get this to record anything, then it's just another player and of no use to me! PLEASE HELP ME ASAP! Happy Holidays and thanks!
post #96 of 100
I've been having recording issues as well, it was working fine about 4 months ago but then it started to record only part of shows. I called the tec support and they said they were aware of the problem and were working on a fix. This was a while ago so I called back a few weeks ago and they said they were still working on it and would send me a disk to put in an update the unit. I sort of gave up but low and behold the disk showed up today.
I put the disk in and it took a bit to read. After it did it said on the TV to hit the record button 3X and then it started to update the unit. I looked at the disk on my PC and it only has one file named:
LG_DR100_8603NT_UPDATE.590
I have not tried to record anything yet but, I've zipped the file and tried to upload it here but it's too big to attach. I've zipped it and uploaded it to rapidshare, here is the link.
I'm guessing if you burn that to a DVD it may work for you too. I bet it would be just best to call and ask for one though.
Not sure how many times you can download that but send me a PM if you want it directly or maybe some one can put it somewhere better.
post #97 of 100
Sorry I guess I need three posts before I can put up a URL
post #98 of 100
So one more, sorry I just thought someone would be interested in this because the issue is so annoying.
post #99 of 100
post #100 of 100
I am not getting 5.1 audio and the sound is cutting out occasionally. It is connected via HDMI to a Sony HT-CT100. It does the same thing when connected via HDMI to my Samsung DLP. The sound did not cut out when connected via component, but the CT100 does not have component connections. Anyone have this problem and know of a resolution?
  Back to Forum: DVD Recorders (Standard Def)
