AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Help with Definitive Supercube III
post #1 of 5
I recently bought a supercube III but when I plugged it in.......it had no power and since it came without the manual, is it possible that it has a blown fuse? Can someone help me. It doesn't have an off/on switch and the light is off. Have hooked it up but nothing. Any help would be greatly appreciated.
post #2 of 5
Checked the fuse and looks intact.
post #3 of 5
If you've verified that the fuse AND power cord (and outlet) are OK, then you're looking at a trip to the shop for your sub. Is it still under warranty?
post #4 of 5
How do you like your supercube III
post #5 of 5
Have you tried a dvd or music? It takes a lfe signal to turn it on.
