Ok so after looking at everyone elses theaters, and what not, perusing the forum for ideas, gathering necessary equipment I've decided I should go ahead and put my project that I've just recently started out here.
My house is a new home built in 03', it has what is called a dedicated media room upstairs that has up until this point housed my old Toshiba 57" CRT HDTV and a few miscellaneous components for surround sound. I had a Media PC hooked up to it running through the RGB connections mostly used as a very nice progressive scan DVD player. I also recently switched from DirecTV to Time warner because they actually offer better HDTV offerings and their HD-DVR is free. The dimensions of the room are 18'x13'x8'. I hope to conceal the equipment and media in a media center shelf unit that comes 2' from the wall to surround the existing projection CRT while the 76" screen is hidden in a cabinet mounted to the ceiling in front of the shelving system. With the media center in place it will bring the length of the room closer to 16'. It's already drywalled and carpeted and essentially like a large bedroom with no closet. In the end I hope for the project to look something like what I've illustrated below.
http://65.65.5.149/fawcett/MediaRoomtext.jpg
Now before I begin I have to give special thanks to:
Walmart, without their really cheap paint and clearance hardware and fabrics this project wouldn't be possible.
Woot.com, without them selling me the Infocus Screenplay 5000 with pull down screen for $735 shipped this project would be dead in the water.
Lowes, thank you for having that sale on lumber, it really helped!
So what is the goal of this project? Well to be honest it's to build the best acoustic and aesthetic theater I can for under $4000 I have a running total right now and it's funny I've already spent most of my budget and I've still got to get seating, so in the end this may get fun and creative. Here's a short summary of what I've purchased thus far and what I already have.
Infocus Screenplay 5000, $735 woot.com
50' x3' x 1.5" roll of linacoustic $140
100' x 3 a 1" roll of linacoustic $180
Lots o' lumber on sale from Lowes $187
Misc. parts and supplies from Walmart $80
Hy-tech paint additive (waste of $32)
Paint $68
Fabric from Walmart clearance $40
Roofing Felt $20
R-19 Insulation $25
Garage door hinges $12 (I know you're thinking huh)
Staples, Nails, and screws, glues and putty $70
Crown Molding $220
Mounting bracket for projector $35
Subtotal :$1844
What I already have and intend to use:
Receiver Pioneer VSX-D811
Yamaha vintage 15 year old speakers (still sound great and are of high quality)
Sony powered 10" sub
Home built media PC with a DVD rom
Various pics.
Before:
http://65.65.5.149/fawcett/before1.jpg
http://65.65.5.149/fawcett/before2.jpg
http://65.65.5.149/fawcett/before3.jpg
Cleared out:
http://65.65.5.149/fawcett/before4.jpg
http://65.65.5.149/fawcett/before5.jpg
http://65.65.5.149/fawcett/before6.jpg
Painted:
http://65.65.5.149/fawcett/painted1.jpg
http://65.65.5.149/fawcett/painted2.jpg
http://65.65.5.149/fawcett/painted3.jpg
Lumber:
http://65.65.5.149/fawcett/supplies1.jpg
http://65.65.5.149/fawcett/supplies2.jpg
Paint $68
Roofing Felt $20
R-19 Insulation $25
Crown Molding $220
Subtotal :$1844
Various pics.
Before:
Cleared out:
Painted:
Lumber:
I think Tigerdirect had a deal on a motorized 108" for $129 the other day
. I think I'll stick with my small screen for a little while since I designed the theater around it and it will take some effort to change all of that. Besides I used to think 57" was huge, 76" is insane to me!
