I recently purchased the Anthem AVM 50, which comes with the Gennum video processing capability built in. It can input and output pretty much any resolution you'd care to use. It has extensive tweakability (contrast, brightness, tint, hue, noise reduction, edge enhancement, gamma adjustment, motion adaptive processing, all per each input). Believe me, it is a tweaker's dream. Anyway, I have the 1140, and would like your opinions on...
1) Several people have commented that when the input resolution equals the panel's native resolution, results would be better because that would involve one less scaling operation. Does anyone know whether 1366 x 768 would be possible via a firmware upgrade to the 1140?
2) Like most of us, I'm using DNice's settings. Anthem recommends that for best results, you'd turn off all panel video processing. Has anybody tried this with their outboard scalars, and if so, what were your results?
3) Is anyone running with this combination (AVM 50 or Statement D2 and an 1140), and if so, what settings do you recommend?
Thanks in advance,
Ron
