post #1 of 1
I had a brand new nForce 4 SLI 133-K8-NF41 and it wouldn't post, figured it was a bad BIOS chip. The heatsink fit perfectly but I had to return the MOBO to Newegg.
Newegg was out of stock, so I ordered the identical mobo from another vendor.
After I removed the stock heatsink mount, I noticed the fasteners were different:
http://img162.imageshack.us/img162/7...rssmallyd2.jpg
The heatsink is designed to screw into the mobo's backplate like this:
http://img303.imageshack.us/img303/6...amlargeob3.jpg
The new backplate is designed for those cheesy plastic connectors. When installed the heatsink mount should look like this:
http://img519.imageshack.us/img519/4...cesmallcw6.jpg
And this is the bare stock mobo:
http://img124.imageshack.us/img124/9...essmallle8.jpg
How do I get a new backplate that will accept two screws and will also fit the heatsink?
