I need to split an analog cable TV signal 7-8 ways.
In my test set-up it would be helpful if I could connect my cable modem to the splitter as well.
I figured since I was splitting that many signals(6+modem in test, and 7 or 8 ways in the final set up) I should get an amplifier.
I looked on ebay, since I didn't know where to start really, and found the following products:
Viewsonics 8-Port ProFormance VSMA-608c-10R Signal Booster
0-1000 MHz
Forward Boost:
+4.0dB
Each port is +4dB higher than the input signal - approximately DOUBLE.
5-42 MHz
Return Path Loss:
0.0dB
Return Path Distortions:
Second Order: -73dBc
Third Order: -55dBc
@60 dBmV Output
Fully DOCSIS 2.0 compliant
PDI-804AR-6KV
Bandwidth Forward: 54-1000 MHz
Gain - Forward: 4 dB
Passband Flatness: ± 1 dB
Return Loss: 16dB min.
Noise Figure: 2.4 dB
RFI Shielding: >- 123 dB
Port to Port Isolation: > 25 dB
CTB - Forward: - 73 dBc
CSO - Forward: - 60 dBc
Max Output: 25 dBmV
Bandwidth Reverse: 5-42 MHz
Gain - Reverse: - 1.5 dB
ELECTROLINE EDA-FT08100 XSP
Forward Passband 54-1000 MHz
Return Passband 5-42 MHz
Forward Path Gain 3 dB
Return Path Loss 0 dB
Surge Protection 6000v
Any recommendations or comments would be helpful.
0-1000 MHz
Forward Boost:
+4.0dB
5-42 MHz
Return Path Loss:
0.0dB
Third Order: -55dBc
@60 dBmV Output
PDI-804AR-6KV
Max Output: 25 dBmV
