AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › OFFICIAL Samsung LN-S4095/4695/4096/4696 Owners Thread
OFFICIAL Samsung LN-S4095/4695/4096/4696 Owners Thread - Page 154
post #4591 of 4596
Originally Posted by raistline View Post
Just scan can be accessed when you access Picture Mode, It will be one of the options --wide fit, wide fit zoom, zoom, 16:9, and finally JustScan
Originally Posted by Rob Kenny View Post
Finally had the upgrade work. I re-formatted my flash drive and instead of running the .EXE on the drive, I expanded it to a file then copied the files over.... How do I find JustScan? I can't find it. The TV now works with BD-ROM 24p as-is...
Awesome, thanks guys!
For a 6+ year old TV, this thing has been awesome. *knock on wood* no complaints and no issues.
post #4592 of 4596
White pixels, thousands of black jumping "grains of rice." - so bad it is not only annoying but obscuring the picture. So . . . have decided to upgrade to a 3-D Panasonic. Tried using compressed air to clean the screen and the mirror, but no joy.
post #4593 of 4596
Mirror?
av-n
post #4594 of 4596
Or whatever is in there - was doing it through the air slats.
post #4595 of 4596
Originally Posted by K4SMX View Post
***DO NOT ACCIDENTALLY INSTALL THE WRONG FIRMWARE FOR YOUR MODEL***
Hello all. This has been a very helpful thread!
Sadly I was too confident to double check the model number of my TV and successfully flashed the '96D firmware onto my (previously) working '95D and am now stuck with a nice brick. I was wondering if anyone here knows how to manually flash the correct firmware onto this set. I'm a fairly competent electrical engineer (except when I'm not reading model numbers apparently...) and have access to a flash reader/writer so I could desolder the firmware memory chip if someone happens to have the firmware binary. Any help would be much appreciated. I feel bad recycling this perfectly good TV because of a software issue!
post #4596 of 4596
If you are unable to find the binary I have heard of people on this forum buying a new circuit board for pretty cheap.
