AVS › AVS Forum › Audio › Speakers › Infinity Primus Owner's Thread
Infinity Primus Owner's Thread - Page 108
post #3211 of 3700
Got my 163's today. Bigger than I anticipated. Looks good though. Trying to figure out if they are going to be able to handle front mains properly.
post #3212 of 3700
I blew my tweeter in my Primus center channel (don't know model). Where can I buy replacement speakers?
post #3213 of 3700
I was able to get a replacement tweeter for a Primus 360 tower direct from Harmon (Infinity) at about $24.
Super easy replacement
post #3214 of 3700
http://www.harmanaudio.com/search_br...=PRIMUS300/230
post #3215 of 3700
I am really enjoying the P163's and the PC351 I got. I still want to get p363's and move the P163's to surrounds.
post #3216 of 3700
I too have the P163's, PC351 and P162's for the Surround and am continuing to really enjoy these speakers!
post #3217 of 3700
Purchased a pair of P362s off Craigslist with a blown tweeter. Looks like part number is 85DA20AJ-DT05-E.
Anybody have a spare tweeter that they'd be willing to sell or know where I can get one for less than $30? Harman is out of stock and only alternative I can see is buying single P153 and replacing tweeter that way..
post #3218 of 3700
Just got off the infinity website and they have raised the price of the 363's. They use to be 199 and now they are 329.
post #3219 of 3700
http://reconingspeakers.com/products...-p362-tweeter/
$35 plus shipping.
post #3220 of 3700
Why is it so hard to find a PC351 up here in Canada? O.o I'm just missing that center to finish off my 5.1 setup!
post #3221 of 3700
These speakers seem to be hard to find everywhere. I am having difficulty finding the primus 363's.
post #3222 of 3700
Given that the P362 is identical except for color and model, have you considered that?
post #3223 of 3700
Yes I have. I just don't like the looks of the 362. Maybe I should look at the 360.
post #3224 of 3700
Any suggestions on a wall mount for the P153?
Seems like it's pretty heavy at 13 lbs and I don't think attatching it directly to the wall will be a good way to put it. Need to rotate, angle down slightly...
post #3225 of 3700
Look at this: http://www.amazon.com/gp/product/B00...00_i00_details
post #3226 of 3700
thanks a lot. I was looking into those. Do i have to screw the speaker to the base or will the clamp, alone do the trick?
I'd like to avoid drilling holes in the new speakers if possible.
post #3227 of 3700
Yeah, so the 153s got delivered today. I guess i should have paid more attention to the specs. These things are really massive and my wife doesn't want them mounted on the wall in our living room. I'll have to probably give them to my brother or something. no point returning them, they are more than worth the low price i paid on newegg.
lesson learned... set up your home theatre before you get married.
Any recommendations for something smaller? the 143s don't seem like they'll be any better (and they are more expensive). I was looking at the TSS-SAT800. Any other recommendations are welcome. Thanks.
post #3228 of 3700
They look smaller the higher you mount them. Just like the moon!
13lbs feels heavy to the hand, but your wall can handle it. Put in a couple of dry wall anchors (like these http://amzn.com/B0051IALCI) and you could hold 5x the weight (or get a screw into a stud). Rotating and angling is just making some calculations. I mounted my 153's in a corner last weekend and went though the same thing. I attached a terrible drawing of how I mounted mine. I wanted them to fire directly out of the corner, so I made 45 degree angle cuts on a 7 inch piece of wood and mounted the speakers flush with that piece. By bringing the screws out, I could adjust the angle that the speaker fires. This was in the top corner of the wall, so they were pretty much flush with the ceiling also.
Edit: Now I'm adding pictures.
While I had the saw out, I cut up an Ikea shelving system to hold the TV over the massive PC351. Wife almost killed me when I brought that thing out, this seemed to placate her.
post #3229 of 3700
I kept showing my wife pictures from the dedicated home theater forum. When all I wanted to do was put some 163's on my walls, all of a sudden it seemed perfectly reasonable!
post #3230 of 3700
I am surprised by the price increase of the primus line. I got my 163's for $85 per speaker two weeks ago. Now the cheapest I can find them is $140. Does not look good for me finding the p363's for less than retail.
post #3231 of 3700
Crutchfield has them in stock at $85 right now.
The prices seem to be cyclical. I have bought most of mine from Electronics Expo, and they have great prices when the speakers are in stock. Over the past year, I've seen them go in and out of stock quite a few times. When I was looking to complete my set, I bookmarked Crutchfield and Electronic Expo's Primus pages, and check them once a day until I saw the prices I wanted.
post #3232 of 3700
I see the 162 at those prices but it says $140 for the 163.
post #3233 of 3700
Ah, fair point.
post #3234 of 3700
Anyone know if Infinity is going to come up with new series for this spring? Like P364s? haha.
post #3235 of 3700
Not likely. There is nothing mentioned on the Infinity website and the current top line Primus is the P363. Strangely enough, there is a picture of the Cascade Nine which has been discontinued, as well as the Prelude 40, another line that has probably also been discontinued (although you might be able to get one @$6K).
http://www.infinitysystems.com/home/default.aspx
http://www.infinitysystems.com/home/...USA&Country=US
post #3236 of 3700
i am a newbie to avs and new to infinity speaker owner i just went to best buy today and picked up the pair of infinity p253 and the pc251 centre channel (wanted the p 363 and pc 351 but didnt have the cash hahaha)so far they sound awesome , they had the p363in stock but were 449 each and the pc351 is 399 i didnt have that much cash at this time so i got the p253 for 135 each and the pc 251 for 130 i couldnt pass up that deal just means ill have to upgrade down the road to the 363 hahahaa now gotta finish it off with a nice small surrounds thinking maybe the p143's and an infinity sub looking at the 10" or 12" and gotta buy my onkyo 609 reciever then maybe ill buy 2 subs hahahha im just peasing it together now but ill get her done hahah also looking at an emotiva amp to power the 253 or when i get the 363 hahaha call me crazy
post #3237 of 3700
Hi Guys,
Looking for some advice, I tried it as a separate thread but didnt get any response so I thought I should try here.
I have Infinity interludes in front IL10 and IL25C for center and a Velodyne DPS-12 Sub-woofer, I was wondering if Infinity Primus p143 will be a good match for the surround. Looking for small speakers to go with the front speakers. Any one running this type of setup with success or have opinion?
Currently I am using Acoustic Research AR215PS speakers for surround.
post #3238 of 3700
Originally Posted by Jazz Khan View Post
Hi Guys,
I see no issues. They will probably be a better match than my Interlude IL-60s, IL-36 fronts and Cambridge Soundworks The Surround 5.1 side surrounds. I found my rear surrounds beside the street that someone had put out as trash. If you manage your Large /Small and crossover frequencies the 143s will work fine. Got my daughter a pair of 142s a few years ago to use with her IPod. Right out of the box I was amazed. I don't think matching surrounds to fronts is a real high priority in most households.
post #3239 of 3700
Thanks GLBright, Yes I have denon 1712 which has separate crossover for center, front and surround. I was just not sure how MMD tweeter will play along with CMMD ones on interludes.
post #3240 of 3700
Hey guys, looking at upgrading my old Infinity Reference towers to some of these Infinity Primus, likely the P362. I am not against buying used, and wouldn't mind saving myself a little money. I plan on keeping an eye out for any of these on ebay/craigslist, what would you consider a fair price for the P362 used?
  Back to Forum: Speakers
