AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › JL Audio Fathom F113, F112
post #1 of 60
Has anyone read a recent review of the new JL Audio Fathom subs? I am a dealer and just received my first shipment a couple of weeks ago. Both subs are very impressive both in output level and musicality.
I was just wondering if anyone else had any comments or an actual listening experience.
post #2 of 60
There was a lot said about them after they were first announced at last year's show, but I haven't seen any tests on them. From all accounts they look to be very good performers, just a bit pricey, competing with very high-end subs. I would like to see a couple of objective tests on them.
post #3 of 60
My review of the f113 is in my November column in Stereophile.
Kal
post #4 of 60
I'd read through your review in stereophile, but it didn't like other recommended equipment's reviews. Those were more detail and tested in depth. The most important thing was that f113 wasn't classified whether it's highly recommended by stereophile or at least which class it belongs to... this made me a bit disappointed... I think it's a product introduction rather than a review...
post #5 of 60
Do a search here and you will find a lengthy thread on the Fathom. I have two F113s and they are great.
post #6 of 60
As part of the on going subwoofer shootout being done here, these are the direct 2 Meter GP measurements from the DD-18 and the Fathom 113. These may be of some assistance when recommending a sub. :
DD-18 @ 16 Hz:
DD-18 @ 20 Hz:
DD-18 @ 25 Hz:
Fathom 113 @ 16 Hz:
Fathom 113 @ 20 Hz
Fathom 113 @ 25 Hz
post #7 of 60
Let me clarify... what I was disappointed was only about Kal's review, but not f113's capability and potential!!
post #8 of 60
It was reviewed as part of the column, and not in a stand-alone review, per Stereophile's editorial policy. Yes, I, too, would have liked to see some measurements.
Ratings for all components are assigned with the publication of the Recommended Components in April and October and the f113 will be included.
post #9 of 60
So do you mean f113 will have a detailed review in stereophile later? And is it a recommend subwoofer? Which class it belongs to??
post #10 of 60
It is, currently, editorial policy to not have stand-alone reviews of subwoofers (and certain other components).
To quote myself: "Ratings for all components are assigned with the publication of the Recommended Components in April and October and the f113 will be included."
You will have to wait until the April issue for more information.
post #11 of 60
I recall that in the past there were stand-alone subwoofer reviews. The most recent one was subwoofer Genelec and James. They both belongs to class B!!
post #12 of 60
Not many reviews out,yet. One thing is sure the new JL Audio f112 and f113 outperform many established products from very respected companies.
Having owned over 50 subs and having two dozen at home I can say the f113 is without any doubt reference class,there is no compact sealed subs that even touch this unit,when maximum performance is key.
Built like a tank,quality of cabinet to the controls is first rate.It is an all around winner.
post #13 of 60
Personally I think Mark Seatons "submersive-1" sub is going to give it a run for the money,,stay tuned
post #14 of 60
Time changes things.
post #15 of 60
like I said stay tuned
I now own one of these monsters
post #16 of 60
I will stay tuned,for these.In output should be good to go,now it is all in the quality of the sub bass.To beat a f113,strongly doubt any sub can do this.
These are ported I guess.No ported bests a sealed in quality.In any case I will get a SubMersive.
SubMersive and BMF are on my list,as well as TC Sounds upcoming MONSTERS.
TheEAR hears it all,all the subbass that is.
post #17 of 60
The Submersive is a sealed sub and the quality of the bass is top notch in my opinion
post #18 of 60
I was going to wait for the Submersive, but the size is just a little too big for my WAF, and imo it is not as nice looking as the f113 either. To be honest the size of the f113 is pushing it for me anyway. The Submersive is much cheaper than the MRSP of the f113, but street pricing brings them really close. If their performance is similar, all things considered, I personally would still go with the f113. Mainly because of size and looks. If for some reason the Submersive really outperforms the f113, then the equation changes of course. It would still be too big in size for me though. Like I said, I'm pushing it with the f113, and it's really not that big in the first place.
post #19 of 60
I thought the submersive was going to be a PR, or is that the BMF? Is the submersive a dual-driver, sealed, push-pull alignment?
post #20 of 60
Question...It uses one or two drivers(opposed sides)?
The single driver I see does not have the displacement of a W7. It would have to be two drivers in that case.
post #21 of 60
Yeah, the BMF is the PR based unit (and even bigger yet), the Submersive is a dual 15" sealed unit.
post #22 of 60
Yep, two 15" drivers opposing sides.
post #23 of 60
Indeed, there are 2 15" opposing drivers that produce no vibration because of placement and design so this means that at full romp this sub will not "walk" across the surface as a front firing might, also the box would need to be twice the size if both drivers were on the same side of the sub, it is powererd by a 1000w digital amp which is very light and produces much less heat
post #24 of 60
The "street" pricing of the F113 is still nowhere near the price of the Submersive. (unless you know something I don't)
-Eli
post #25 of 60
Dual drivers,opposing sides.I could guess by looking at the pics.Very good idea ,opposing drivers cancel each other,vibration is reduced to...next to nothing.
Two solid mid-priced 15" woofers will match the 13.5 ubber excursion JL W7 in displacement.
Makes sense
post #26 of 60
-Eli
Do you know this first hand? Have you checked with various dealers? I can tell you I got a great deal from my dealer! I consider a few hundred dollars fairly "close" or "near".
post #27 of 60
I have checked with several dealers and the best price was a long way from "a few hundred dollars" difference.
-Eli
post #28 of 60
-Eli
Some of us are just lucky I guess. I have a very long standing relationship with my dealer, and I get great deals on AV gear because of it. Others I know have similar experience with their AV dealers.
Btw, Very nice HT setup you have there Eli!
post #29 of 60
post #30 of 60
Fun, may I ask why you are getting rid of the SMS-1 and going with something else?
